HP incr. from cam change
Old Oct 23, 2001 | 05:13 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
I am pretty sure next spring I am swapping out my TBI and going with a carb. And to maximize it I am sawpping out the old peanut cam for somethin nicer. NOW, I saw the fastburn 385, then they took that engine and put in an LT4 hot cam in it and got 430HP, now concidering they went from a decent cam to a good cam and got 45 HP, what could I expenct from a good new cam? 45-60?
Especially if I swapped heads, not enough $ for that though.
1 5/8 Hooker Competetion Headers, custom y-pipe,no cat, modified Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat, BF G-Force w-rated tires
Old Oct 23, 2001 | 05:15 PM
Car: 92' RS
Engine: LO3
I failed to mention that the engine is a 305 LO3
Old Oct 23, 2001 | 05:49 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
to get an increase of that nature, you need to increase rpm. A 305 is not really intended to turn rpms over 5500 without major expense. I would expect something more in the range of 20 additional hp on a cam alone.
Old Oct 23, 2001 | 06:17 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Since you already have headers, it might be more than 20 HP, but probably less than 40. You might see 30-35 HP with the optimum cam selection. Something with about 212-218° of .050" duration on the intake, about 10° more than that on the exhaust, about .480" lift, ans a lobe separation of about 112° would be about as far as you'd want to go. Check out the Comp line of computer-compatible cams, the 264HR would be in that neighborhood.
ICON Motorsports
Old Oct 24, 2001 | 07:34 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Well shut my mouth:
Carcraft March 99.
A 305 with 80K miles, a performer rpm (they also tried a vic jr with similar results), headers and a XE268 made 270hp at 5100rpm. The engine gained 40hp from a stock cam to the XE268.
I guess rb wins another
[This message has been edited by jcb999 (edited October 24, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
camaro71633
Sep 1, 2015 10:24 AM
nuggie
Aug 25, 2015 01:27 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
