Pickup Coil Install
Old Oct 24, 2001 | 09:05 PM
Justin Moore's Avatar
Car: 1986 Z28
Pickup Coil Install
I bought a new pickup coil and there is some white tape going around the actual wires. I thought this was just to protect the part but when I took the old one out it still had the tape on it. My question is: Do I remove the tape before installing the pickup coil or do I leave it?? Also where do the wires connect to, as they seem to be loose.
Old Oct 24, 2001 | 09:36 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Leave the tape in place. We just did one on our 350TBi work truck. The wires attach to the Ignition Module that mounts to the distributor deck. The wires should have a connector connected to them.------------------
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
[This message has been edited by Rob P (edited October 24, 2001).]
JETHROIROC's Avatar
Leave the tape on it. It just provides further insulation for the coil, even though it's probably shellaced. The wires from the pickup coil terminate in a connector that connects to the ignition module. Hope this helps.
1990 IROC 350
Mods: Too busy trying to make it run right to mod it.
Airfoil, Dynomax cat-back, MSD coil, 180 t-stat, Bald Eagle tires,
Hypertech fan switch, Accel 23# injectors, Holley module, ported plenum,
Ported Daytona Yellow stock base, Moroso valve covers, other stuff,
Streetdampr, Ruger P95DC, hot wife, new oil filter, !cats, !TBC, !AIR.
18.0 @ 85MPH since I'm one big-a$$ MF
"It's better to have and not need than to need and not have."
Azrael91966669
25
Jun 20, 2017 04:04 AM
apo_bailon15
Mar 28, 2016 05:20 AM
TheExaminer
Aug 25, 2015 07:34 PM
Winchester1094
Aug 18, 2015 10:23 AM
transamgta1Khp
Aug 17, 2015 12:18 PM
