what should vacuum be at idle
Transmission: A4
I think i have a vacuum leak and need to hook up a gauge to find out. the leak must be big enough to cause my idle to go up and down and i cant set timing on new motor until i get it to idle right. where can i hook up the gauge to
there is no set number your engine will run at, connect the gauge to any port in the intake.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 2002 SOM z28
For what it's worth, I run about 13"-14" at 900 rpms...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
