Heads and Accessories
Old Oct 26, 2001 | 06:56 PM
BringBackThe80s's Avatar
Putting together a 400. I'll be using a set of "double hump" heads (I already have them, don't have the dough for aftermarket super heads). My question is, since these heads have no accessory holes, does anyone make brackets to relocate the alternator and power steering pump? I really need to make these work. Thanks in advance.
Dan
Cameron NC
Old Oct 27, 2001 | 09:42 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
With 400ci and 69cc chambers, you will have very high compression with flat tops, too high for cast iron and pump gas anyway.
It would probably be less trouble to get the right heads if you need all the accs. (ps, alt, ect.)
If you just need an alt bracket it shouldn't be to hard to find though. I believe most or all these setups used a short water pump (I may be wrong)
Hope this helps at all.
Old Oct 27, 2001 | 11:33 AM
Thanks for the reply. Actually, not using flat tops, using "dished" piston. Compression should come out to about 10.1/1 I think I've solved the accessory problem,March Performance Pulley seems to have what I need. I'll know for sure this week. I agree that it would be alot easier to get different heads, but I'm building this engine on a tight budget (USAF is a great job, but you won't get rich) and I already have the double humps and don't want to spend another 800 or so dollars for aftermarket heads if I can avoid it.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
