Pulleys, oil leak fr. crank
Old Oct 28, 2001 | 01:42 AM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
When I put on crank/alt pulleys, when removing the old crank pulley, some oil dripped out through the damper behind it. Should I be concerned about this? I just wiped up the drips of oil and put on the new smaller pulley... is it normal for a little oil to come out like this?
BTW, my $.02 re. the pulleys - definitely seeing the power drop at idle (6-700), down to 12- V range w/lights dimming, but normal charging ~14 V above idle... I do a lot of city driving with this (to/from school), so I'll post if this causes any problems (e.g., kills new battery). A definite bit of increased more low-end power, so I'm happy.
Joel Geerling
91 Formula, 305 TBI
Edelbrock 14x3 open element
TBI 1/2" spacer
Hypertech street chip
Pulleys and exhaust are next!
Old Oct 28, 2001 | 02:09 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Thats usually just oil that creeps up the snout of the crank between the balancer.
No biggie.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
[This message has been edited by Engineboy (edited October 28, 2001).]
Old Oct 28, 2001 | 11:10 AM
Car: 91 Formula
Engine: 305 TBI
thx for the reply, engineboy.
Old Oct 28, 2001 | 02:42 PM
jag's Avatar
jag
If you think it's leaking at the balancer, they make a sleeve ($2) to put on it to seal up to the timing cover correctly where the seal usually wears a groove in the balancer neck. You have to have a machine shop press it on, but it will save you alot of money over a new balancer ($75). Check with your local machine shop, they probably have several in stock since this is a common Chevy problem.
[This message has been edited by jag (edited October 28, 2001).]
xxx3man`
Sep 23, 2015 10:37 PM
mddaniel
Sep 8, 2015 05:16 PM
Navy8125
Aug 21, 2015 09:32 AM
drathaar907
Aug 6, 2015 04:20 PM
