Autometer Oil pressure sending unit, where do you install it?
Old Sep 12, 2005 | 05:14 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
I have a 91Z28, the oil pressure sending unit for the stock gauge is located above the oil filter, the only thing is that is also the oil pressure switch that cuts the fuel pump if the oil pressure drops, so I guessing I can't remove that stock sending unit.. How else can I install this sender so I can use the autometer gauge? Thanks
Old Sep 12, 2005 | 05:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Top of the block beside the distributor.
Old Sep 12, 2005 | 06:27 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Install it either on the top by the distributor or use a "T" and have both down by the oil filter.
Old Sep 15, 2005 | 08:15 PM
SLAYER6669's Avatar
Excuse my ignorance but do you have any more specifics on where exactly next to the distributor? Is it visable by just looking or will I have to remove anything? Pic would be great if possible
Also, will I need any specific adapters to make this work? I'm not sure what kind of room is there but the sender is a pretty sizeable round thing.. What sizes do I need if I do?
Thanks guys
Old Sep 15, 2005 | 08:17 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Look for a pipe plug on the block behind the intake.
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
Irocohio
Aug 12, 2015 08:03 AM
