oil pressure on start up but goes down after warmed up
Old Oct 29, 2001 | 06:05 AM
BOTTLEDZ28's Avatar
Transmission: A4
I just installed a new gm crate motor in my 91z28 350 tpi and noticed that the oil pressure reads about 30-40 on startup and then goes down to 0 after about 10 minutes of driving. I have not hooked up a manual gauge to it yet. where is the easist place to do this. some say the oil pressure switch( brand new) but if that is taken out then will the fuel pump turn on. dont they work together.
Old Oct 29, 2001 | 11:34 AM
Black 84 Z's Avatar
Car: 1984 Z28
Engine: 350ci
Axle/Gears: 3.73 12 bolt
I had the same problem after i had my engine swapped. It was indeed the oil pressure switch (which was leaking). After i got that fixed the gauge was peaked straight up because the sending unit was bad. Got it replaced and all is well. good luck
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
