Did rocker arms and injectors Now the
Old Sep 14, 2005 | 10:59 AM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
OK i did 1 6.1 roller rocker and new 24lb injectors on my 88,350 TPI. I put the top back together and now she will surge at idle. As soon as she warms up, it will almost seem like she was running normal again. Any help on why it surges would be great!
Old Sep 14, 2005 | 11:27 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
did you get a chip or change the injector constant in yours? if not, that is probably why. also check for vacuum leaks.
Old Sep 14, 2005 | 12:26 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
How do you change the injector constant ?
Im not sure what you mean? I didnt change the chip.
Old Sep 14, 2005 | 04:55 PM
87zjeff's Avatar
when i went to bigger injectors, i didn't change my chip. all my car would do at idle is surge. the injector constant is the part of the programming that tells the ecm how big your injectors are. so, your ecm still thinks you have 22lb injectors.
Old Sep 14, 2005 | 05:31 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
Oh,so the only way to get rid of the surge is to get a chip made or put the stock injectors back in?
Old Sep 15, 2005 | 09:41 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
yup
Old Sep 15, 2005 | 04:13 PM
DA BRONX's Avatar
Car: 1987 GTA
Axle/Gears: 373
thanks
morrow
Jan 13, 2024 12:29 PM
BAMiller
Sep 14, 2015 06:38 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
