Calculating Compression ratio?
Old Oct 29, 2001 | 05:41 PM
gruveb's Avatar
Car: 1989 IROC-1
How do I roughly calculate compression ratio?
I am doing some half-hearted research into a couple (4 actually) different engine combos.
What formula can I use to roughly come up with my a compression ratio.
Let's suppose for a moment that I use the same standard size head gasket on all applications, and that I can choose between flat top or domed pistons.
http://www.gruveb.com/z28
Old Oct 29, 2001 | 08:12 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
go here
http://home.tampabay.rr.com/yz250/calc.htm
Old Oct 29, 2001 | 08:56 PM
Vader's Avatar
...or if you have MS Excel or Quattro Pro, load this file and plug in your numbers:
Engine Calculator
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 29, 2001 | 09:17 PM
gruveb's Avatar
Car: 1989 IROC-1
Thank you both.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
PurelyPMD
May 5, 2016 04:57 PM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
