fuel pump strainers, 1LE
Old Oct 29, 2001 | 06:19 PM
Eightyninef's Avatar
In my ever stride for information on replacing my leaking gas tank.. I have learned the following.
There are 2 different strainers for a GM fuel pump. both are available from GM.
one is a strainer for all 3rd gens, the other is a 1LE only strainer. I am almost sure there is only 1 fuel pump. so can you put a 1LE strainer on a non 1LE? I have the part numbers, but not handy at the moment.
I'm thinking of ordering both strainers, and just diving in. if it fits great, if not only $14 spent. (The 1LE strainer is about double the price) Does anyone know what the difference is?
Now just some general info. as of a few years ago, there is only 1 replacement gas tank for all 3rd gens. this includes 1LE's, TTA, and V6 motors. all the same replacement tank.
Larry
still collecting parts to replace tank.
89 Formula
96 Impala SS
Old Oct 29, 2001 | 09:24 PM
here are the numbers:
strainer, part 25139035 fits 3.8 v/6, 5.0 and 5.7 engines
strainer part 25027354 fits 5.0 and 5.7 with 1LE option only
Old Aug 13, 2002 | 03:48 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Larry,
What did you end up doing?
Old Aug 13, 2002 | 03:52 PM
go with the 1le Strainer available at pepboys. it's double ended, rather than single ended. I used the GM pump and the lastest release GM tank.
all my fuel problems are gone..... !!
Old Aug 13, 2002 | 03:59 PM
Omega's Avatar
Engine: LS1 / LS3
Wow, that was quick!
Is the tank worth the $240? I know you race but I am having trouble justifying it.
Old Aug 13, 2002 | 05:06 PM
how did you did up this old stuff? it's a year old
I had to buy a tank, mine was leaking all over the place. so yeah, $240 well spent. better than burning my car down, or even my house. fuel was leaking on the exhaust.
I did the fuel pump while it was apart. I did the exhaust cause it was rusted through.
now the car is pretty much perfect. no more fuel starvation problems.
Gm screwed 89 owners by not recalling the tanks like they did in 90. oh well.....
Old Aug 13, 2002 | 05:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey, thanks for that info, Larry! I have to drop my gas tank to weld a 1/4 panel in, I was thinking of changing the fuel pump (for the third time) with a GM one instead of the Borg Warner one from Pep Boys. Are those GM part #s or Borg Warner or ...?
Old Aug 13, 2002 | 07:06 PM
I used all GM parts with the exception of the pulsator which was a BW.
Old Aug 14, 2002 | 08:35 AM
Omega's Avatar
Engine: LS1 / LS3
I used the search button!!! Ya know, that funny little icon that no one uses? Yeah that one
Since I have revamped my suspension it seems to keep bogging around hard turns. I just bought a GSS340 pump so I was debating upgrading the tank as well.
What is a pulsator?
Old Aug 14, 2002 | 09:16 AM
upgrading your pump won't help your problem.
2 ways to solve your bogging problem.
keep the tank full
or
replace the tank with the lastest and greatest tank from GM
Old Aug 14, 2002 | 09:41 AM
Omega's Avatar
Engine: LS1 / LS3
I read a couple of posts saying that it will, but that is not the reason I bought the new pump. The new engine will not tolerate the stock pump.
Old Aug 14, 2002 | 05:30 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The pulsator is the stupid useless thing between the pump outlet and the tube inlet. Looks like a little square. Supposedly GM puts it in between the two to "quiet the pump". Guess what though? The pulsator only attaches to those tubes with o-rings. If your pulsator gets old, or if you re-use a pulsator instead of buying new, the o-rings can leak!
First time I changed my pump, I didn't know that; I re-used the pulsator. When the pump died again 2 years later (damned borg warner, next time will be AC!), I didn't use a pulsator. I used a short piece of high pressure fuel line (included in the new fuel pump's box) and two small clamps. I didn't notice any problems, and if the pump is louder, I sure as hell can't tell. Do a search on the TPI board for "pulsator" and you'll find a ton of messages.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
gta90
Sep 15, 2015 04:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
