Will a 305 TPI setup work for a 350 engine?
Old Oct 30, 2001 | 02:28 AM
nesluopetan's Avatar
AS you guys know, im looking for a tuned port setup ASAP for my camaro.. I have had a guy tell me he will sell me his TPI setup complete w/ harness, comp, etc. He said the only thing is it is from a 305 engine, and that it uses 19 pound injectors compared to 24, he said it shouldnt be a problem, but i need two opinions.. this new motor im getting is about 280hp, 350ci.. so would that work or would I have to change all 8 injectors, if so how much does each injector cost? i need help guys, i really need a TPI setup, let me know if anyone can help. email me
nate
Old Oct 30, 2001 | 04:10 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
There are a few more differences besides the injectors. And 350 L98s have 22lb injectors, not 24. Lets see, the knock sensor is different, the ESC module, and the PROM in the computer. I think those are the only differences. On the 19lb injectors you can get an adjustable fuel pressure regulator and bump up the pressure. That'll make up the difference in the flow. None of these different parts I mentioned are exactly critical. I mean the 350 will run with the 305 parts. It just won't run at its best; there will be slight problems with fuel delivery and spark advance/retard.
91 Z28
Come see The Vicious...
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
squiggy2
Aug 9, 2015 09:30 PM
drathaar907
Aug 6, 2015 04:20 PM
