non-thirdgen but could ya help anyway? :)
Old Oct 28, 2001 | 09:47 PM
tacoboy's Avatar
Okay, I know I ask alot of questions on here but this ones actually not about my Camaro. This question is on behalf of my brother about his 96 or so Jeep Cherokee. He has one with a V6 and is generally pleased with it, but when he goes over a pass somewhere around his college his car lags a bit due to the elevation. Now he wants a little more power, but mostly he just wants the power to not die so much up there. Any recommendations for him? I said a K&N and exhaust work should help alot towards his goal. How but it guys? Help him out? Thanks.
Old Oct 29, 2001 | 12:08 AM
Vader's Avatar
TB,
Elevations can be pretty tough. These are the places that a MAF system excells, since it actually measures the mass of air entering the engine. I would suspect a newer Jeep would be using a MAF, but I'm not certain.
The best solution would be a turbocharger, but that might not be an option. Aircraft piston engines have had great success with turbos at high altitudes for decades, and even turbojet and turbofan engines benefit from a similar effect.
Obviously, a good clean air filter is a good start. A less restrictive exhaust may not be as great a benefit, since there really isn't that much volume of air moving at those elevations anyway. Still, there is always an argument for a free-flowing exhaust system.
Another thing to monitor in elevations is the coolant temperature. It is very easy to overheat at altitudes, since the heat is rejected less effectively. If the PCM detects a higher engine temperature, it will tend to lean the fuel mixture and retard the spark timing, which simply adds to the problem at altitudes.
It might be worthwhile to consult a Jeep dealer, since they may have a solution similar to what GM had for their cars destined for higher altitudes. IIRC, there used to be some adjustment made to programming on GM cars to correct this. The MAP engines were particularly sensitive to altitude changes, and I seem to recall some TSBs that involved a replacement PROM.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Old Oct 29, 2001 | 12:51 AM
tacoboy's Avatar
hmm, thanks for the suggestions, i' ll tell him to ask what his dealer has to say. i think we will do the cat, and filter like i suggested anyway as well.
Old Oct 29, 2001 | 07:57 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
there isn't a v6 available in a jeep cherokee. for what he has though, they do make a cat back system as well as cold air induction systems. i believe mopar makes a performance computer also for it but there should be plenty of companies like jet or hypertech that make plug in performance modules for it.
Old Oct 29, 2001 | 09:13 PM
Enkil's Avatar
Yeah, aren't the inline-6's?
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Oct 30, 2001 | 06:35 AM
zippy's Avatar
Engine: 5.3L
correct.
Old Oct 30, 2001 | 01:23 PM
tacoboy's Avatar
yeah thats correct, i forgot guys, cut me some slack
Corry
Jun 6, 2003 11:28 AM
Gumby
Oct 11, 2002 10:29 PM
Red Devil
Sep 9, 2001 08:04 PM
formulafb91
Aug 9, 2001 09:49 PM
