how do i check air/fuel ratio?
Old Sep 16, 2005 | 08:52 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
i thought i read somewhere you could strip back the wire to the oxygen sensor and use a DMM to check it but i couldnt find it searching. i know how to use a dmm, and i dont want to buy any expensive equipment, and dont really want to take it to a shop.
Old Sep 16, 2005 | 09:20 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
Look in the tech article section, it's in there.
Old Sep 17, 2005 | 04:05 AM
1meanGTA's Avatar
sorry
Old Sep 17, 2005 | 11:01 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Its a waste of time, really wont tell you all that much. The best way is to use a wideband and standalone controller if you just want something to monitor the engine. Innovate makes a nice handheld unit. There is also a barebones inline controller from them that puts out a voltage only signal.
Old Sep 17, 2005 | 12:06 PM
1meanGTA's Avatar
those are pricey though, yeah?
Hotrodboba400
Dec 10, 2019 07:07 PM
64goatman
Sep 9, 2015 01:09 PM
TBRays98
Sep 6, 2015 05:05 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
