cleaning ground wires
Old Sep 17, 2005 | 08:31 PM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Does anybody have a trick to getting at & cleaning the ground wires behind the passengers side cyl. head.
Old Sep 19, 2005 | 03:49 AM
Tony89's Avatar
Car: 1989 IROC-Z Convertible
Transmission: Art Carr 700-R4
hope this helps
I just finished a head swap....and actually learned a few things in the process. My '89 has a 3/8-16 stud in the back of the pass. side cylinder head with a hex in the middle...GM seems to like these things. If yours is the same as mine, the hex is a 9/16 inch, and the nut on top of it is also 9/16. On mine, that stud is used hold the firewall ground and a thick tab that anchors the AIR system pipe. It's a bear to reach but if you get a short 9/16 wrench (open end on one side, box end on the other with 12 point opening) your best bet will be to get it from below. The twelve point closed end will allow you to rotate the nut slowly, without needing 60 degrees of "sweep" to move it. Without that, it will be even worse. I hope this helps. Good luck.
Old Oct 3, 2005 | 08:39 AM
TABBOO's Avatar
Top Answer: 1
Car: 87 T/A
Thanks for the reply. It turned out to be a couple of bad pins in the ECM plug & a frayed TPS wire. Thanks again!!
Old Oct 3, 2005 | 11:27 PM
Tony89's Avatar
I'm glad to see you found the problem
It's good to hear a happy ending. Good luck.
Glowsock
Jul 24, 2025 03:15 PM
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 19, 2015 12:07 PM
