probably sounds dumb, but what is a stroker kit?
Old Oct 29, 2001 | 11:07 PM
cort351w's Avatar
I think the subject says it all. please respond
Old Oct 29, 2001 | 11:31 PM
yellowiroc2's Avatar
Car: Z06, WS6
Engine: LS6, LT1
Transmission: M6
basically a larger crank... 305, use a 350 crank, 350 use a 400 crank... etc.
Bird_of_Prey's Avatar
Car: Formula
Engine: 400 sbc
it's putting in a bigger crank then the engine came with.. like a 400 crank inside a 350 givies you a 377 and u bored it .030 over so you get the 383 stroker.. (most popular and well known stroker) u stroke an engine so you can get more cubs out of it w/o changing the block to something else (and above 350.. well.. nothing in between that and a 400 sb).. neways.. more cubs is equal to more power and so forth.
87 formula
LB9, Automatic
K&N
3" catback v-force muffler
Hypertech preformance chip
Old Oct 30, 2001 | 02:26 AM
Jza's Avatar
Jza
The rod journals on the crank are farther from the center, giving the pistons a longer throw or "stroke". Since the piston moves farther up and down, it displaces more air than with the old crank. Just in case you were wondering about the semi-technical reason.
Old Oct 30, 2001 | 08:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
305 and 350 cranks are the same (usually casting # 442) with the same stroke (3.48"). You can't stroke a 305 by putting a 350 crank in it; if you put a 350 crank in a 305 block, you come out with {expectant drum roll please} a 305.
For both a 305 and a 350, a "stroker kit" consists of a 400 crank with its mains turned down to the 305/350 size; and either a set of standard 400 5.565" rods and standard 305 or 350 pistons, or standard 305/350 5.7" rods and special pistons.
IMHO it makes no sense whatsoever to do this to a 305. Even if you already own the 305, it's cheaper to go out and buy a 350 block and simply rebuild it than it is to go through the stoking bit. Plus, the 350 comes out with more inches; more torque, more HP, goes faster, less money, less trouble.
ICON Motorsports
Old Oct 30, 2001 | 11:33 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
<font face="Verdana, Arial" size="2">Originally posted by cort351w:
I think the subject says it all. please respond</font>
Don't worry about sounding stupid. We were all newbies here at one time, and 99% of the folks answering questions here are really good eggs that don't lord it over those who are less knowledgeable
Old Oct 31, 2001 | 01:53 PM
cort351w's Avatar
Thanks, y'all. I was confused when I heard about stroker kits, because it didn't sound at all like actually having the block stroked, and I had never heard of a stroker kit. Thanks again.
Old Oct 31, 2001 | 05:38 PM
Enkil's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Sitting Bull:
</font>
Yeah, besides... Some of the experienced people still sound stupid from time to time.
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
New2Chevy
Sep 28, 2015 12:35 AM
Mickeyruder
Sep 2, 2015 02:45 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
masonta
Sep 1, 2015 06:40 PM
