335 stroker woe...
Old Sep 19, 2005 | 04:25 PM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
335 stroker woe...
hi,was drivin as usual today,then engine was runnin rough>>>!
while going around 55mph...pulled in at home,it wanted to die out whilst idling!!!?checked the spark plugs-they were good.re-installed my original EPROM-still didnt do it!???wires checked out OK too.
now i had it rebuilt maybe 20k ago and since then NO PROBLEMS....everything was replaced...i found NO trouble codes from the self-diagnostic feature either!
i havent been able to run high octane gas as per the TBI EPROM that i had in it,i thought maybe it was from inferior gasoline causing it to run that way???but to no avail....still runs ultra rough! any thoughts third gen heads????i really been trying to finger this 1 out, I DO NEED EVERYONES THOUGHTS FOR A SOLUTION
PLEASE,TY-BRAD
Old Sep 19, 2005 | 06:16 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Rough as in a miss, a knock, a rattle???????
Old Sep 20, 2005 | 04:37 AM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
it seems to be more of a miss than anything....no knocks or rattles.i have new tbi injectors i installed also!still the samething happening....i wonder if it could be vacuum or maybe the EGR???I WONDER?????????????ANY THOUGHTS...........????
Old Sep 20, 2005 | 12:50 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
things that always have made my car miss like crazy. this way maybe at least give you some ideas of where to start
plugs gapped too far or needing replaced. found out looking good also doesn't mean they are good. might need those replaced. also double check your gap. too large of a gap will cause problems
spark plug wires. easy check on those though. grab a multimeter from someone and check their resistance. not 100% effective on finding out if they are bad but hey it still might lead you to theright direction if the resistance is very high or you don't even get a reading. your resistance reading I'm assuming is going to be around 6k-15k ohms but I'm not sure the specs. someone else might be able to give you the info on the specs
timing. having the timing misadjusted will always cause problems.
get a cheap vacuum gauge to read your vacuum.
try a compression test if you get a chance also
another thing you said you had it rebuilt 20k miles ago right? that means you should of had some driving time on it. did you change anything around the time it started messing up? add something try working on something anything?
Old Sep 20, 2005 | 12:55 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
forgot about the EGR that you brought up it can cause some problems also if it is sticking
Old Sep 23, 2005 | 06:30 PM
sennap1's Avatar
Car: 91 TRANS AM
Engine: 350 V8
Transmission: 4L60
Axle/Gears: 3.43
WELL I CHANGED THE PICK-UP COIL AND it still runs the same!!!i did notice the brake pedal was hard to depress when i took it for a test drive!!!im thinking it could be a power-booster or a vacuum problem possibly????? any thoughts FELLOW 3RD GEN HEADS????
Old Sep 23, 2005 | 07:18 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What sort of chip tuning have you done? If the answer is none than I would start there.
Old Sep 24, 2005 | 12:59 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
start pluggin vacuum lines till something changes.
Old Sep 25, 2005 | 05:34 PM
montesa311's Avatar
Car: 83-84 camaro, 95 formula firehawk
Engine: 305, 305ho, 350tpi, 350 lt1, 383lt1
Transmission: 700r4, t-5, t56, m6
Axle/Gears: 3:90, 4:10, 3:50, and more
you need to determine if its one cylender doing it or a random miss fire... then we have somewere good to start from... easiest way to find that out.. wile its running, pull the plug boot of the plug and see if it evens out...... steadies out..... how far it bogs down compared to other cylenders doing the same procdure on them..
83RDRACR
Mar 26, 2016 08:13 PM
Nervous2
Oct 8, 2015 10:53 PM
86z89iroc
Oct 5, 2015 01:04 PM
Chevykid810
Sep 28, 2015 12:57 PM
JSDaddy189
Sep 26, 2015 03:50 PM
