coolant issue need help
Old Sep 19, 2005 | 11:53 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
ok i was driving home and started to smell a burning coolant smell i saw white smoke coming from under the hood so i looked under and saw the smoke was coming from the passanger firewall near the accumulater the coolant was landing on my hot exhaust and i saw a big puddle on the floor need help
Old Sep 19, 2005 | 11:58 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
...... Search that area for a coolant leak? I don't believe there are too many hoses there.
Old Sep 20, 2005 | 12:01 AM
Car: 91 formula
i cant see where the smoke was coming it is cramped in that area what do you think is wrong
Old Sep 20, 2005 | 12:45 AM
Elthesh's Avatar
Car: 1991 Pontiac Trans Am
In that particular spot, it sounds a lot like the heater core hose. Hopefully I won't be giving you bad advice here, but if it's anything like mine, the hose should come out of the firewall and towards the front of the engine, passenger side into a valve with other hoses going into it. Check that hose first. If it's not exactly like mine, you should still have a similar setup. Heater core hose from firewall to some kind of valve. Most likely either this hose or another hose has either split, got a hole in it come kind of lose or the clamp has fallen/rotted off. If it is a hose, best bet it to get a new hose the same length, new clamps at either end, oh, and... here's a warning...
If the valve is the same as mine, due to the age of the car, you are very likely to break it getting the hose off. I grabbed hold of my defective valve to remove the hose and the plastic outlets the hoses go on, two on em shattered off inside their hoses. You might wanna get a new valve to be on the safe side. You can always return it for a refund or just fix it at the store and buy the valve if it breaks there. If you ever lose heat from the climate control system inside the car, that's a likely culprit for being broken inside too, the valve.
Old Sep 20, 2005 | 10:54 AM
Car: 91 formula
ok i determind it is the heater core. its on my 87 formula 350 is it hard to change do i need a special tool is it a paid in the a$$. I got got a brand new heater core for $19.99 it was $99.99 the guy at autozone screwed up.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
Accerrito22
Sep 5, 2015 09:34 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
