removing a/c???
removing a/c???
hi everyone, i have an 86 iroc 305 w/ ac that doesnt work and i was thinking bout removing it.... does anyone know anything bout how i should go about this/or can give there $.02? thanks...
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I used a A/C delete pully on my 91 Z
if you go to the dealer I thik there like 50 bucks
but I think your 86 migh be a differant part # though so that price might not reflect what you's will be ...
I got mine barely used for 40
hope that helps some
Hecubus
Check out my site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~ 175-200hp shot/ 255lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt./Pro-Built stage 3 700 R4/ACT 2400 stall converter/Trans-Go shift kit
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Hecubus
