homemade cold air intake
Old Oct 28, 2001 | 11:41 PM
Rockhound's Avatar
i was thinkin of makin one using 3" diameter aluminum heater hose from a hardware store runnin down underneath the car. i was just wondering what should i attach the hose to where the air will be entering. what type of scoop?
Old Oct 29, 2001 | 06:22 PM
Chevy83Z28's Avatar
I'm wondering the same question, curious to see the answer. Will a 3" round house fit a 6x2" opening? I believe the internal area of a 3" circle is greater than that of a 6x2" square/oval...
Old Oct 29, 2001 | 07:55 PM
Rockhound's Avatar
ive finished mine finally. i stuck a short piece of black PVC pipe inside the alumninum hose. i drilled holes through the PVC to attach it to the underside of the nose of my car. works pretty good. kinda keeps the engine cool. when someone's revvin the motor and i stick my hand in the pipe, i can feel it suckin the air in. its pretty strong, sucked a few screws all the way up to the air filter. mines carburated.
Old Oct 29, 2001 | 08:02 PM
gruveb's Avatar
Car: 1989 IROC-1
Got pics?
There are some older threads on this subject, but the pictures don't work anymore.
http://www.gruveb.com/z28
Old Oct 30, 2001 | 08:34 PM
Chevy83Z28's Avatar
Rockhound, exactly what kind of hosing did you use? I've been to the local Home Depot store, and couldn't find any hosing that would work. They had some 3" hosing, but it was too stiff to be able to be bent enough to fit the 6x2" opening on my dual snorkel air cleaner.
Do you know the brand of the tubing and where'd you buy it from? Thanks so much!
Old Oct 30, 2001 | 09:23 PM
speedtendancy's Avatar
go to your local
Home Depot and buy the aluminum tubing used to expell the hot gases from driers...worked fine on my 88....$8
Old Oct 30, 2001 | 11:15 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I used a different setup using the TPI induction system on my RS. I thought about doing it the way that you guys are doing it and I thought of a few things...
You could use and IROC grill and run the ducting into one of the fog lamp housings, I don't know the dimensions but if the hosing is too big you can take care of that with some tin snips. If its too small you can expand it with additional pieces and some extra work...
You could also run the hose into one of the headlamp housings, I know a lot of people that have done it with their chevelles. They'll pull the headlight and hook up the hose during drag racing, or if they just want headlights they'll put the light back in and plug it back in. Others have put it into their turn signal locations...
I've seen other people do it using an old oil bottle and trimming the piece to fit. I didn't think that that would work that well, but the structure of the container actually isn't that bad, but depending on where you put it, it looks kind of tacky...
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Old Nov 1, 2001 | 09:56 PM
RacingRoc2's Avatar
I made a ram air system for my 86 305 tpi... it worked great.. i can def notice a diff w/the airfoil and ram air. I used 3" dryer duct and routed up from the fog light tubes into this box i made from sheetmetal that i pop rivitted to teh air box for tpi. if you have any questions email me at MOBOGRND13@aol.com
Old Nov 1, 2001 | 10:44 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
yah rockhound PLEASE get some pics of it cuz i gotta friend and his dad is a plumber and owns his own shop and he can custom bend and get me anykind of tubeing
so please get some pics cuz i really wanna know how to make my carbed single snorkeled L69 really breathe like it should!!
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Hooker Cat-Back
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
stalkier
Dec 6, 2015 11:25 PM
hayesaw0210
Aug 23, 2015 11:15 PM
kyle5647
Aug 15, 2015 11:56 PM
