Homemade AFPRs
Old Oct 31, 2001 | 10:31 PM
Fred91TA's Avatar
Car: 1991 Trans Am
Transmission: 4L60
Homemade AFPRs
Can someone tell me exactly how to make my own AFPR? I ordered one from Summit, not knowing really what one consisted of, and was amazed. I paid $72 for a piece of anodized aluminum! It's a joke and a scam. It's going back tomorrow and I'll spend the money on something worth spending it on. Any help is greatly appreciated.
91 TA 5.7 TPI Automatic
w/WS6 and 3.23 rear.
K&N Cone Air Filter (at the end of the plastic tube), Hypertech Coil, Moroso Blue Max Wires, Bosch Platinum plugs, JET 180*fan switch, JET air foil, Dual cats with Flowmaster 3" cat-back, GM Performance PROM, Complete PST components on front suspension, Spohn LCAs/Panhard bar.
My car only uses Mobil 1 synthetic fluids.
Old Oct 31, 2001 | 11:27 PM
BitchinCamaro's Avatar
https://www.thirdgen.org/newdesign/tech/tbi-afpr.shtml
straight out of thirgen.org's tech section
Old Nov 1, 2001 | 09:15 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Is that the same regulator as a TPI? Doesn't sound like it. I know Vader has a link, but it never seems to work when I look through old posts. I'm interested in doing the same thing less than $5 seems alot better than $50-70 for something I probably won't use very often anyways. How much HP can the 19lb injectors feed at stock psi?
14.62@96mph headers, muffler, chip, ghetto stuff, duct tape
89 GTA 305 TPI 5 speed 3.42 gears
Old Nov 1, 2001 | 10:54 PM
Vader's Avatar
Fred/Beast,
I have a file with instructions. I'll warn you (and everyone) one more time - read and heed the caution about the ball size if you decide to use a ball instead of a flat steel disc. Because of the mail I've had about the fitment problems, I would suggest using the disc instead of the ball, even though I found the correct size ball for my regulator. (The steel disc from a 3/4" conduit knockout is about a perfect fit.)
The PDF file is here:
AFPR Conversion.pdf
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
alpine247
Sep 16, 2015 05:25 PM
355tpipickup
Sep 4, 2015 05:32 PM
