Oil & Oil Filter
Old Nov 2, 2001 | 11:10 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
Oil & Oil Filter
Would you suggest I use synthetic oil in my 92 RS, it has 114,000 miles. I bought it about a month ago and I was just wondering what oil & oil filter to use. Currently the car has no visible leaks.
Old Nov 2, 2001 | 12:27 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Stay away from Fram, just buy an AC Delco one. Currently I am using a Fram because that's all Wal-Mart had at the time, but next oil change I am going to buy several AC Delco filters. It will be more important for you to change your oil on a consistent basis than to switch to synthetic. Personally I use Mobil 1 synthetic.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 2, 2001 | 04:37 PM
89BlwnRs's Avatar
I'd say change to synthetic. You'll reduce friction between the components in your engine, helping to prevent wear between components. Furthermore, synthetics are more versatile. They flow better hot and cold, and are more resistent to thermal breakdown. Basically if your car is running hot, that synthetic will protect better. On a cold day, the synthetic will flow easier than regular, lubricating the engine better and earlier than a regular oil. There's really no reason not to switch to a synthetic besides cost.
Also, synthetic does not cause leaks or make them worse. Since it flows better, it'll find it's way through a small leak much faster and probably more regularly than regular oil.
Jason
[This message has been edited by 89BlwnRs (edited November 02, 2001).]
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
89 formula TPI
Sep 7, 2015 11:06 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
