im hearing a squeel from the back of the car. not breaks
Old Nov 2, 2001 | 02:47 PM
david foraker's Avatar
its coming from the back of my car but its not from needing new breaks cause it goes away when i apply a little pressure on the breaks. any help is appreciated
Old Nov 2, 2001 | 03:27 PM
85transamtpi's Avatar
Guess what?
Its the brakes. I'm guessing that you have rear disk brakes and your parking brake doesnt work. If the parking brake cable is broken the rear calipers have no way to adjust themselves so as the rear pads wear, they will become loose in the caliper (and make noise). By pressing the brake you get them to seat properly and the squeak goes away.
If your parking brake does work, use it!!! If it doesn't, fix it (or have it fixed). I could be wrong but Im pretty sure that is what is happening but I could be wrong.
peace
[This message has been edited by 85transamtpi (edited November 02, 2001).]
Old Nov 2, 2001 | 03:35 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Remember when you tied you dogs leashe to you car because you were tired of holding it?Well.. hate to tell ya but..haha just kidding.
I need more info like when does it get louder?
89 Formula Firebird
Red with T-tops
5.0 305 FI
Soon to be a 400sb.
Old Nov 2, 2001 | 04:10 PM
well i dont have rear disks. i have the drum. right after i start up my car and drive it starts. if i leave it in park, then no squeek. when i put it in drive and start to roll over 10 mph it starts. but when im breaking it stops, till i take my foot off the break
Old Nov 2, 2001 | 04:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's something to do with the brakes. Just pop the drums off and look, no sense arguing about it over the Net, it probably will be obvious.
ICON Motorsports
Old Nov 2, 2001 | 06:46 PM
Vader's Avatar
DF,
I'm guessing that you have semi-metallic or ceramic/carbon fiber linings on your rear shoes. These are particularly prone to noise when "coasting" which disappears when the brake pressure is applied.
The phenomenon really doesn't indicate any problems or unusual wear or damage, but certainly can be annoying. One possible cure, if only temporary, is to remove the drums and scuff the wear surfaces inside with a rough sand paper to remove any polishing. I say temporary, since before you know it the drums will have a polish again and could begin the "whining" all over.
Later,
Vader
If you want to beat the World, it might reach up and pull you down...
Adobe Acrobat Reader
Jeremys87
Jul 14, 2022 09:08 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
db057
Aug 22, 2015 08:17 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
