Desktop Dyno
Old Oct 31, 2001 | 11:43 PM
Dauntless's Avatar
Desktop Dyno
anybody have this? how accurate/effective is it? i'm kinda interested in getting it. it'd seem to give me more information at ease than anything else. of course, i'm still in the researching phase of my modding. and i'm kinda in the "getting money for modding" phase as well. probly gonna be here for a while. hehe.
1984 Z-28, 305HO 4bbl, t-tops, K&N, Flowmaster 80 Series with 3" tips. Planning a massive modfest. It's gonna be one gangsta of a street demon.
Old Nov 1, 2001 | 12:13 AM
BadSS's Avatar
Check this link out to see what David Vizard thinks of it.
http://www.motortecmag.com/current/products/index.html
I've been using a version of performance trend's software and prefer it myself. It seems to be a lot closer to real dyno pulls either I or customers have had done in the past.
edit - Performance Trends seem to reflect the entire rpm scale better,, especially at low rpm. Both versions do a good job at estimating peak power.
[This message has been edited by BadSS (edited November 01, 2001).]
Old Nov 1, 2001 | 12:36 AM
SoCo80p's Avatar
i use it all the time and is about the most usefull tool i've ever used, i use it mostly for cam selections, and the cams i come up with on the D.D. i've run and had fantasic results. one guy i know put in every exact spec of his new engine into the DD (head flow, all cam specs,...etc) and then built the engine and dynoed it and it was within 3 HP from the dyno to the desktop dyno, that sold me on it and i really like this program
Old Nov 1, 2001 | 12:58 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
<font face="Verdana, Arial" size="2">Originally posted by BadSS:
</font>
Almost every dyno estimation I've ever seen DesktopDyno 2000 do has been within 5% of actual numbers, so it is very useful, in my opinion. In one of the latest Muscle Car Review mags they did an estimate of an Olds W30 engine and came up with 310 hp. On the actual dyno it gave them 310 hp. Pretty hard to beat that, eh?
I fyou just keep in mind that it can run 5% either way, you won't be disappointed.
Old Nov 1, 2001 | 02:02 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The accuracy depends on how accurate
your input is. If you tell it lies It'll
lie right back to ya....lol
I find it very accurate when used properly but, by its very nature tends to over estimate bottom end torque. The program always assumes perfect air/fuel ratios and a perfect exhaust design (header). Neither of which happen in the real world. Also a lot more accurate if you use the actual "running seat duration" of a cam instead of the advertized duration or .050" specs. Read the instructions carefully and have fun...
[This message has been edited by F-BIRD'88 (edited November 01, 2001).]
Old Nov 1, 2001 | 11:57 AM
92Camaro305TBI's Avatar
And where does one order this software?
I looked at the link, But I relized it was a MAG! I didn't see anything with desktopdyno.com
92 Camaro 305 TBI Automatic
https://www.thirdgen.org/rides/index...ew&rideid=6100
Old Nov 1, 2001 | 12:19 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
best thing to do is get it from jegs.com or summit. Lowest prices.
Old Nov 1, 2001 | 04:43 PM
720-3616 Catalog Item - DESKTOP DYNO SE $ 24.99
That right?
Old Nov 1, 2001 | 04:57 PM
SoCo80p's Avatar
you want to get dyno 2000, autozone locations have it also/.
Old Nov 1, 2001 | 05:03 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
720-3616
yep
Old Nov 1, 2001 | 08:03 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, you want to get Desktop Dyno 2000, its Windows based and a LOT better than the older DOS version. Here is their website: http://www.motionsoftware.com/ You can get it from Jegs or Summit for about $40. I think its worth the price.
I've put both my engine combinations into it, and both times it was within 10 HP. However it way underestimates TPI's torque. Both times, the number it showed as being flywheel torque is what I made at the rear wheels.
Do a search on this board, you'll find other people's opinions as this has been posted many times before.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 3, 2001 | 05:08 AM
jag's Avatar
jag
I have it, and it is as accurate as you can get without actually doing a dyno. You can input everything from actual flow results of your heads to custom cam profiles, gasket thicknesses, etc.. The more accurate information you enter, the more accurate it will be. I have built engines I've seen in several Chevy magazines that had actual dyno results, and it seems to be right in line with the actual results within a few HP or FT/LBS. I recommend it for use in changing where your powerband will be with different cams or setups especially. Order it, you won't be disappointed. It's fun to play with.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
