Open Air Element and water pump - unrelated-
Old Nov 3, 2001 | 11:50 AM
Buck268's Avatar
I bought a K&N air filter for my L03 a little while ago, and would like to think I did not waste my money, although I would like to put on an open air element. Is there any open air cleaners anyone has seen that would fit this?
Also, I need to replace my water pump, any recomendations?
Thank you
Old Nov 3, 2001 | 02:35 PM
Enkil's Avatar
There are plenty of aftermarket open element air filters you can buy, most of them found at AutoZone. Although you might have a hard time finding one small enough to fit the stock size air filter (and therefor I'm guessing the same size K&N).
As for your water pump issue, Stewarts!
89 iroc-z 305 tbi
k&n filtercharger, open element air filter. nuffin' else
Old Nov 3, 2001 | 02:56 PM
Buck268's Avatar
how much do Stuwarts water pumps run for?
Old Nov 3, 2001 | 03:51 PM
Enkil's Avatar
Ermm.. I think I payed around 80 or 90 for mine, after tax & shipping or whatever else went into the cost of it.
http://www.stewartcomponents.com
I also went ahead and bought a high-flow 180* thermo while I was at it. *shrug* why not? heh
In any case, I've definately been very happy with the pump since I've got it, even though I did have a problem with the pulley bolts shearing off... But they were the stock bolts that came with the car, and had nothing to do with the pump itself. (I think I torqued them down way too much.)
89 iroc-z 305 tbi
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
