What needs done before starting a car that has set for a year?
Old Sep 26, 2005 | 06:30 AM
1QUIKTA's Avatar
Any precautions to take before attempting to start a 92Z 305 after sitting for a year?
TIA,
Chris
Old Sep 26, 2005 | 07:51 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
(#%! I saw an article on the net on this that was very detailed but I cant find it. It had things such as gas stabilizer, put rags in the tail pipes so rats dont nest in there, tire pressure recomendations, put down plywood to absorb moisture or something....
Old Sep 26, 2005 | 01:17 PM
ndamron's Avatar
Car: 82 Trans-Am / 83 Trans-Am
Engine: Major Mod SBC / Minor Mod SBC
Transmission: Major Overhaul 700R4 / Stock 700R4
Axle/Gears: None!!! / 3.73 posi disc...soon
well first check to see what you might have lost after it was sitting, like oil or tranny fluid on the ground, if it looks clean or that very little has driped out, it should be fine.
check your coolent
check around engine too see if you have any nests
also since it sat for a year all the crap in the oil would have settled in the bottom, i would drain the oil toi get all that crap out.
if you have a carb or TBI, right before you start it, dump a half a cup of fuel down the intake, then start.
oh yea, dont forget to bring a extra battery in case the one in the car is dead.
after running the car check fluids again, the car might smoke or smell different for a while, old gas burns a little different.
Have fun
~Nick~
Old Sep 26, 2005 | 10:51 PM
1QUIKTA's Avatar
Thanks, I had already done everything you listed. Just changed the oil this morning. Good news, after a starter and new battery she started up. The car sounds pretty good too.
Appreciated,
Chris
Old Sep 26, 2005 | 11:04 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Take it easy on the go fast pedal till you burn up the old gas that was left in there. It loses it octane rating over time which could lead to detonation. Wouldn't hurt to add a 1/4 tank of premium to bring up the octane a bit. Other than that, sounds like you have everything covered.
Old Sep 27, 2005 | 06:15 AM
1QUIKTA's Avatar
Got ya, as soon as it is road worthy I plan on getting some good premium gas in her.
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
86Base
Aug 8, 2015 01:34 PM
Sherpajames
Aug 7, 2015 06:56 PM
