IROC & GTA steering column.. question
Old Nov 4, 2001 | 09:25 AM
Steve R's Avatar
I have an '89 ASC GTA with the steering wheel radio controls.. and the column is getting a little messed up, and I have the column from my '88 Iroc. They have the same options, except for the radio controls. Will the iroc column cause a big problem if I try to use it in the GTA?
p.s. keeping the radio controls are not a concern
Old Nov 4, 2001 | 09:53 AM
Guest
Guest
Posts: n/a
Define 'messed up'
And to answer your question:
Yea, it will work fine.
Old Nov 4, 2001 | 10:03 AM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Does the '88 have VAT's? I think your '89 does.
Old Nov 4, 2001 | 10:06 AM
Steve R's Avatar
The steering wheel is extremely loose, and feels like it's about to fall off in my hand. I'm going to go try to tighten the screws in a few minutes.
And yes, they both have the PASS key thingie
Old Nov 4, 2001 | 01:08 PM
Guest
Guest
Posts: n/a
Well, generally a loose column is the 4 screws that hold the tilt mechanism together, fix that (make sure you use loctite on the bolts unless you wanna do it again) and it will be fine.
Old Nov 4, 2001 | 11:40 PM
Steve R's Avatar
I looked at it before, and a bunch of the bearing ***** were all over the floor under then column, not good. I ended up just swapping out the column and re-using the lock cylinder for the VATS. But thanks for the advice, guys, it bolted right up!
Now all i need to do is replace the power steering line i busted getting it apart and life is good
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
