Oil leak, rear seal?
Old Sep 26, 2005 | 05:13 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
Axle/Gears: 3.42 posi
I have a pretty decent oil leak going on. If I let the car idle in one spot for 15 mins or so then I have a oil spot about 5" big right under where the tranny and engine mount up. Im thinking its either the oil pan gasket (please let it be this) or the rear main seal. Im leaning towards the oil pan since my flywheel is bone dry. If it is my rear main wouldnt I have oil all over the flywheel?
Old Sep 26, 2005 | 06:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
When my rear main seal went, I had oil in the bell housing, on the clutch disc, and the rear side of the flywheel.
JamesC
Old Sep 26, 2005 | 09:01 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
Thats good news, I will be changing the oil pan gasket in class Wed and will update then.
Old Sep 27, 2005 | 06:46 PM
Parrydise7's Avatar
I got a pretty good deal on a 1969 Chevelle because the owner thought the rear main was leaking. It wasn't. Somebody replaced the oil pressure sending unit and didn't bother to tighten it down. It was leaking like crazy.
Old Sep 27, 2005 | 09:35 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
The dizzy and oil sending unit were the first things I checked out along with the valve cover gaskets. I got the seal today and am putting it in tomorrow. Hopefully I will be posting a happy post tomorrow saying it was the oil pan. I love how I need to raise my engine to get the pan out
Old Sep 28, 2005 | 01:56 PM
vrtc350's Avatar
Car: 81 Corvette
Engine: 355, ported vortec heads
The great wall across the back is a common culprit as well.
Old Sep 28, 2005 | 05:00 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
I changed the gasket today and found that the rear passenger side 1/2 bolt that holds on my pan is stripped in the block. I put it all back up and its not leaking yet but I will be doing a retap or helicoil on it tomorrow. Atleast it wasnt the rear main.
Old Oct 3, 2005 | 03:10 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
Okay it wasnt the china wall. Im out of ideas. I have replaced seals/gaskets on the following:
Valve cover gaskets
Oil sending unit
Intake
Oil pan
Dizzy gasket
I cant think of anything on the back of the block that can be leaking. If its my heads I would think I would be having more problems then just some oil leaking.
Old Oct 3, 2005 | 03:28 PM
JamesC's Avatar
Isn't there an O-ring or something on the dizzy?
JamesC
Old Oct 3, 2005 | 03:30 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
Y eah I did that too, thanks..forgot to add it to the list.
Old Oct 3, 2005 | 03:42 PM
Parrydise7's Avatar
Sounds like it's time to throughly clean the engine, run it for a short time and then trace the leak.
There may be an additive that glows under a black light that you can add to the oil, (to make it easier to trace the leak) but I've never tried it or even looked for the product.
Good luck!
Old Oct 4, 2005 | 08:41 AM
vrtc350's Avatar
Car: 81 Corvette
Rear main
Old Oct 4, 2005 | 02:31 PM
87_Z28_350's Avatar
Car: 1987 Z28
Engine: 350 (357ci)
Turns out it was the oil sending unit. It wasnt leaking from the threads, there was a crack on the bottom of the can itself.
Old Oct 4, 2005 | 03:27 PM
vrtc350's Avatar
Car: 81 Corvette
Awesome!
Hell of lot easier than a rear main.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
drathaar907
Aug 6, 2015 04:20 PM
