Too much power?
Old Nov 5, 2001 | 06:34 PM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
Too much power?
Hey, I was just about to start the process of rebuilding my engine when I came across what I thought could be a problem. I'm going to stroke my 305 and probably put a supercharger on it. I hope to get close to 400hp with a coupla other mods. Is this to much power for my rear end? Will it hold up under 400horses? If not, what kind of rear end is the best to use? Thanx.
Old Nov 5, 2001 | 07:05 PM
SoCo80p's Avatar
i would say it would be fine, the 305 doesnt make a whole ton of torque, and if your just going to run regualr street radial tires you'll be fine.
Old Nov 5, 2001 | 07:25 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Are you changing your heads or cam while your at it? Just currious as my cars in pieces at the moment being rebuilt. I'm building it for a supercharger and am looking to make about 330-350bhp naturally aspirated.
Good luck and e-mail me if you like.
Robert
Old Nov 5, 2001 | 07:31 PM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Thanx, I'll just try my 3.23 posi and if it breaks then I guess I'll check on a new one. I'm fairly new at the whole supercharger thing, so if I have any questions I'll definitly email or post them. Thanx again.
Old Nov 5, 2001 | 09:02 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
You'll probably need to rebuild the trans to handle that power as well.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
