what do u guys think is harder, Taking of Intake, or putting on headers.
Old Nov 3, 2001 | 11:28 PM
breathment's Avatar
Ok, i took off my intake runners and plenum tonight, and well it not to fun, anyways im just curious for all of you who have done this and put on headers, what do u think was harder, how would putting on headers compare to taking off and puting on the intake. i know this sounds kinda stupid, but i really want some headers, i just don't know if i want to put some on.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
Old Nov 4, 2001 | 12:30 AM
firbird's Avatar
i would say yes taking off the tpi setup is a pain but i would have to say headers might be a little bit harder, but it all depends on who does it too, my brother had the hardest time ever tring to get every thing togeter and i did not nearly have the problems he did, one reason he told me his mistakes before i did it so that helped a little, i just took out the front passenger side braket for surpintine and slid it in there without any problems, but my brother did not have the surp, so he had a harder time and i thing went a differnt rought, and what kind of headers are you planing to get?
but i think it is a modification that really is not that bad and hard and also more experiance the easyer things usally happen, if you do it once you prolly can do it in half of the time, such as taking off the manifold.
Old Nov 4, 2001 | 12:38 AM
tacoboy's Avatar
i would say headers are more difficult by far, well not so much difficult, they are both fairly straightforward, but headers are a pain and take time, i imagine swapping headers after you already have a pair would be pretty painless though. anyway, id vote for headers taking more time to do
Old Nov 4, 2001 | 03:22 AM
rezinn's Avatar
The intake is easy compared to headers. On the headers you cannot see half of the bolts you are removing, they are most likely rusted, and its a very dirty job. It also takes probably four times as long. I've swapped intakes twice in a day, but I would never think of swapping headers that much.
Old Nov 4, 2001 | 04:53 AM
Danger's Avatar
Car: 84 TA
Engine: 305 L69
Having just spent the last two days fitting my new headers I can say the only thing harder was changing my clutch. The lack of clearance all round and the need to remove everything within 6" of the pipes makes for a very tedious job. And now I have to make a Y pipe to suit.
84 Trans Am HO L69 WS6
5 Speed manual
Vortech Cherrybomb no cat
JB Headers
Comp Cams XE262H-10
Removed A/C A.I.R. Hdflap
H/made tri cld air induction
K&N
Otherwise STD
Currently painting
Old Nov 4, 2001 | 05:13 PM
cort351w's Avatar
Putting on headers takes a long time. I have a 91 formula WS6 with the LB9. I have spent the last day and a half taking off the exhaust manifolds.
WHAT WAS GM THINKING?? Why are there sheetmetal tabs on the sides of every bolt I had to take off. It took me two and a half hours to take out the farthest back bolt on the driver's side. I had to cut out all of the sheet metal with a dremel, work for about an hour with a pair of needlenose pliers to bend that little tab down enough to get a socket on the bolt, then fight the rusted out bolt.
Seriously, those tabs are rediculous. I don't think I want to put the EGR on my headers--takes up too much room and is ugly.
Old Nov 4, 2001 | 07:19 PM
killer305's Avatar
i put my headers on while the engine was out of the car so that was wicked easy. put putting the y-pip on that was a pain in the a$$.
90 RS 305 tbi, 4 3/4" cowl Hood, Edelbrock TES headers, Flowmaster exhaust, Crane roller cam, comp roller rockers, vortec heads/intake, ported tbi, w/new injectors, MSD probillet Distributer/ coil, 1 inch tbi spacer, air foil, 14x4 k&n flat base air cleaner, Rebuilt 700r4 w/ B&M shift kit, B&M Megashifter, 3.23 posi, 2 12 RF's with mtx amp, top of line alpine cd player, soon to have 90-91 gfx, z-28 wing, new paintjob, rims, and all new lowered suspension.
Old Nov 4, 2001 | 07:54 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Took my brother and I 6 hrs. to put headers on. I have a carbed engine which I assume would be a lot easier taking off than TPI. I would say go for the headers, it's not that bad at least in my experience.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 4, 2001 | 09:13 PM
JJ's Avatar
JJ
I've always had an easy time with headers on the thirdgen's I've owned. I've installed/un-installed hedman and slp shorties on both. The slp are really easy (maybe it is the practice that counts ). Then again, I use headers with no AIR fittings. I've had less fun experiences on tpi itakes in the past - getting ready to tear into one again shortly though . . .
Old Nov 4, 2001 | 09:18 PM
89ProchargedROC's Avatar
lol....i've taken apart my intake so many times it has become a 25 minute chore
WITH NO AIR TOOLS
when i put my IROC back to stock i put it all back together thinking i switched ALL the injector o-rings i had to....
NOPE
took it all apart and had it back together in 20 minutes flat
if i had to do the whole intake....30 minutes
try doing headers that fast...i dont want to think about it
Old Nov 4, 2001 | 11:13 PM
Trent257's Avatar
headers really arnt that hard, its just getting the old crap outta the way tahts a pain
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco cat
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
Old Nov 4, 2001 | 11:20 PM
1989CamaroRs's Avatar
hedders are harder, involves lots of cussing and possbile skinning your knuckles
[This message has been edited by 1989CamaroRs (edited November 04, 2001).]
Old Nov 5, 2001 | 12:29 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Don't forget that bolt by cylinder #7? (closest to the firewall,passenger side) That goes into a rusted unused hole(tap it first to clean threads) Needless to say, with edelbrocks, I made that last bolt considerable shorter with a hacksaw, which helped a lot with the TIGHT rusted threads and needed to do some grinding on a wrench for clearance to turn it anything worth while. Headers are a real b*tch, but they aren't hard to do, just a pain in the a$$.
The worst thing I attacked was setting up 3.73 gears and posi. Just sucked, anything with measurements between .008"-.012" and involves shims suck. I'm going to try a cam/head/valve spring/seals swap in a few weeks, should be interesting. Good thing I can walk to school.
14.62@96mph headers, muffler, chip, ghetto stuff, duct tape
89 GTA 305 TPI 5 speed 3.42 gears
Old Nov 5, 2001 | 01:15 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Headers, grrr... I had to do battle with the evil headers/y-pipe this weekend. But with the help of the Big F***in Hammer victory was mine. Installing headers is pretty much a miserable experience, I'd take an intake any day.
91 Z28
Come see The Vicious...
Old Nov 5, 2001 | 08:38 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
I think it kinda depends on who made intake manifold and who made the headers.
In my case ('87 IROC, 5.0L), replacing the TPI manifold base wasn't more difficult but was just more time consuming. I began swapping the stock manifold base with an Edelbrock one the weekend of the Oakland, CA fire (1991...time flies). It took me about 4 days because this thing was far from a bolt-on; the 'Vette EGR block off plate was in the way, had to fab a custom coil bracket, had to drill and tap AC bracket bosses, among other things as I recall.
With the headers (those old SLP Tri-Y's), The most difficult things were getting the stock exhaust system off and removing the cat from the pipe.
Old Nov 5, 2001 | 11:07 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have installed a few sets on stock cars and its a day prodject with takin your time.
Old Nov 5, 2001 | 12:22 PM
rezinn's Avatar
On the intake manifold, there is nothing hard about it. Very straightforward: remove plenum, runners, bolts, distributor, clean surfaces, new gaskets, new rtv, replace manifold and torque down bolts, replace distributor and the rest of the intake. Simple.
Headers are very different. I did mine when I replaced my heads and intake manifold, it took less time that headers would take alone. All of those metal tabs on the exhaust manifolds were merely an inconvenience; I just took a small screwdriver and bent them outward so I could fit a socket over them. Having the headers inside the engine bay before the heads really helps.
Old Nov 5, 2001 | 08:07 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Installing the headers was pretty easy, same as removing and installing the intake manifold.
Removing the stock manifolds took me a loooooong time, most of the day.
Everything else is cake.
WS6 Trans Am.
View My Ride @ thirdgen.org
Old Nov 6, 2001 | 10:39 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
Headers are a hundred times worse. Removing the stock TPI took me a couple hours because I couldn't find all the bolts. SLP 1 3/4" Headers however have been the bane of my existence .
Old Nov 6, 2001 | 06:10 PM
Zepher's Avatar
Oh, I failed to mention that I don't have Smog or A/C on my car. That makes a big difference.
Old Dec 18, 2004 | 01:14 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
headers are by far harder, took me like 4 days struggling with removal of old ****, and fitting new **** in.
i have swapped a tbi itnake 3 times in one day before (fighting an oil leak) and a tpi over the coarse of one day or two days if i do other crap.
Old Dec 18, 2004 | 01:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
This thread is 3 years old.....
Old Dec 18, 2004 | 01:30 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Holy Batman, atleast somebody has been using
Old Dec 18, 2004 | 02:18 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
i get search and 'new threads' mixed up sometimes and when im searching i see a thread that catches my eye and before i realize it, im replying!
Old Dec 18, 2004 | 03:36 PM
/\/3\/\/l8l3's Avatar
hehe love the "bolt on" headers that take 2 nights to get in
Old Dec 18, 2004 | 08:52 PM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
took me 30 min tops to do both of my headers
Old Dec 20, 2004 | 11:28 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
you have been doing that lately
Old Dec 21, 2004 | 12:47 AM
thecoolone's Avatar
Car: 89 GTA
this is good to hear!
As a car newb, I was a bit worried about wanting to change my intake. I did my headers already, so if the intake is easier I'm happy. For even a car without rust, those manifolds sure rust, and the bolts.... what. a. pain.
Soo, thanks for asking the question!
Old Dec 21, 2004 | 04:09 AM
FireBoid's Avatar
Car: 1987 Firebird, 1997 Camaro
Engine: 2.8L, 3.8L
Transmission: T5, 4L60E
Which is harder.... headers or intake? I'd have to say yes.
Old Dec 21, 2004 | 10:21 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
on many cars i think the headers are harder especially if the intake is setup for a carb. if you have shorty style headers on our cars i would say its a toss up.
Old Dec 21, 2004 | 11:19 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
On my car, I would rather swap out the headers than do a full intake change.
Old Dec 21, 2004 | 01:06 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
and when we are refering to intake.. thats tpi right? cuz a carb or tbi intake is easy as cake.
Old Dec 21, 2004 | 07:09 PM
dual_88s's Avatar
From: In my own little world - but they know me well in here
Car: 88 Sport convertible
Engine: 305TBI
Transmission: AUTO
Axle/Gears: 3.42 rear end
Hooker 2055's aren't that hard.....just don't wrap them
Yippee...this post took me to the lofty status of "Senior Member"
:hail: :hail:
Old Dec 22, 2004 | 01:16 AM
jocww's Avatar
hey anybody got pics of their a/c with headers i have a 84 so that means the a/c is on the drivers side
Old Dec 22, 2004 | 01:18 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
I can get a pic for you.
For my car or a tpi car, I would rather change the intake manfold. Carb is easy, tpi isn't that hard, just takes time. Installing headers was a pain.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
IroczFan
Oct 6, 2015 10:13 AM
86IROC112
Aug 17, 2015 02:00 PM
Jake_92RS
Aug 11, 2015 10:39 AM
