Pre '87 heads on a post '87 motor will they fit?
Old Sep 30, 2005 | 01:06 PM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Can anyone tell me if I can use my 305 S/R torquer heads model 42650-1 on a 1988 305 non roller block?.
The only differance, best I can tell is the intake manifold face and bolt holes are made to fit pre-'87 intakes.
Am I wrong? will I need different length pushrods or can I reuse the ones I have in the '88 motor.? ( so long as they check out OK)
Thanks for the help
Old Sep 30, 2005 | 02:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
They'll fit. I have mine on a '91 crate motor block.
Pushrod length is a function of the type of lifters being used (flat vs. roller). If your original '88 had rollers, then you'll need the longer stock length, '86-earlier, for a non-roller block & cam.
Old Sep 30, 2005 | 02:20 PM
Charman234581's Avatar
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
I have the same type of setup. Pre 87 heads, and post 87 intake. It will be no problem at all except the 4 middle holes on the intake. 2 ways to fix it: buy a new intake, or, wollow(SP?) out the 4 holes so that it will line up. That's the way mine was done and if you like I'll take a picture and post.
Hope that helps.
Old Oct 1, 2005 | 01:32 AM
TBITrucker's Avatar
Car: 88 Camaro
Engine: 305TBI
Transmission: Stock
Axle/Gears: 3.42?
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
89mulletbird
Aug 12, 2015 07:08 PM
slade5612
Aug 11, 2015 07:19 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
