Wires
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
Wires
I am replacing the spark plug wires, rotor, and cap on my 305 tuned port. I purchased Accel rotor and cap..came in a kit, relatively inexpensive. I wanted to get Accel 8mm wires, but cannot find them anywhere for my vehicle...not custom fit anyway...just universal fit, meaning i would have to put the ends on..something i dont know how to do and dont want to really try and then mess it all up. So I had to get Xact wires..they are also 8mm...but I was wondering if anyone who has the Accel's...where you got them for our cars and how much they were....thanks.
1986 WS6-Equipped 5.0 TPI Trans Am
180 Degree Thermo
Manual Fan Switch
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
180 Degree Thermo
Manual Fan Switch
OTHER RIDE:
12/14 Options
Stock(for now)
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I got the accel 8.8 wires and I had to custom trim them. I really am not a big fan of the wires though since they don't block a lot of the electric load and will cause radio interferance and stuff like that. As for trimming the wires it really isn't that bad, you just cut the rubber part to length (leaving a little extra), then leave about a half inch of wire sticking out, fold it over and crimp a lock connector that is supplied. It's kind of nice because it will allow you to run the wires where you want. If I had it to do again I probably wouldn't get the accel wires though...
Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Mike
Car: 99 Formula
Axle/Gears: 342
Like stated above I would go with another brand preferablly MSD, but I was in a pinch at the time and went to Advanced Auto Parts, I'm sure Trak Auto and Autozone, sell them as well.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Engine: 5.0 TPI
Ok....looks like i am staying away from Accel altogether.....thanks for the input guys. Appreciate it.
180 Degree Thermo
Manual Fan Switch
OTHER RIDE:
12/14 Options
Stock(for now)
180 Degree Thermo
Manual Fan Switch
OTHER RIDE:
12/14 Options
Stock(for now)
Glowsock
Jan 9, 2017 04:06 PM
