i have a 454 BBC and an 88 camaro... advice pleez
yo i just got an 88 camaro for free with no motor/ trans. I have a 454 for her that i just have to freshen up but my q is:
-what trans can i use and what will i have to mod for this combo to work??
-money is an issue cuz i have none
thanks guys
89 Firebird Formula
5.0 TPI T-5 WS6 G92 dual cat exhaust 3.42 posi T-tops Grant signature series steering wheel (sweet), Kenwood head unit with Infinity speakers, Accel cap, rotor and wires, AC Rapidfire plugs, K&N Filter, Flowmaster 80 series muffler w/ full 3 inch exhaust, 180* stat, AFPR
New best run 14.8 @ 93mph
thanks guys
89 Firebird Formula
Car: 4
Engine: 6
Transmission: 5
Any trans that will bolt to a small block will also bolt to a big block. The simple and cheap way out would be to put a V8 F-body 700R4 behind it.
Your biggest challenge will be exhaust. There's no cheap ways around that AFAIK.
ICON Motorsports
ICON Motorsports
Car: 99 Formula
Axle/Gears: 342
You're going to most likely have to rebuild any 700R4 to handle the power.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
You're probably going to need a set of headers made for that swap. I think Hooker makes a set. Your 454's oil pan may/may not clear the crossmember. Then there are the engine mounts. You also have to address fuel delivery, as well as engine cooling(i.e. larger radiator). I've been thinking about doing the same engine swap and I asked about it on the engine swap board. Someone there directed me to an article that was done on the subject. You may want to inquire there, as well.
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
All the info you need is on my page, but if you have no money, you shouldn't be doing the bbc swap.
Miles
88 427 Big Block Camaro
(Best 1/4) 12.18 @ 113mph 1.75 60ft
(Best 1/8) 7.76 @ 94mph 1.72 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 posi carriers for sale for 9 bolts
www.koolmeister.com
Miles
)www.koolmeister.com
thanks for the responses... im glad i can run a 700 R4. BTW im using this as a racecar so i dont have to worry about a full exhaust,etc... or street legality :-)
89 Firebird Formula
89 Firebird Formula
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Then don't worry about using a 700R4 in the race car. Depending on what type of racing you intend to do, you'll be better off with a Powerglide, TH350 or TH400.
The swap isn't that hard to do. You'll still need some sort of headers unless you want to use factory cast iron manifolds.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block (times are for the current engine)
Best ET on a time slip: 11.447 altitude corrected to 10.99
Best MPH on a time slip: 119.42 altitude corrected to 124.86
Altitude corrected rear wheel HP: 493
Best 60 foot: 1.586
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.586
ok cool i can get a built th350 for free. what do i need to do to make it work and can i use the same length driveshaft?? thanks
89 Firebird Formula
89 Firebird Formula
i would go with a th400. dependin gon how build your 454 will be, i dont think a th350 is up to it
when the green flag drops the bull$hit stops
Gold 85 Camaro with no motor, pulled the 2.8 to make way for a 350 wich was pulled this summer because a 406 will replace it. The 406 sports a stock bottom end with ARP bolt holding it togeter, flat top hyper pistons. Comp 282 solid cam(.528 lift with 1.6 rockers) Savin up for my Sportsmen 2 heads right now. still Have the perf RPM and 650 DP i used on the 350. Headers and 3inch exhust. Shooten for mid to low 12s next summer
Car: 87 IROC L98
My TH350 is surviving just fine and I abuse it. Don't expect a factory stock one to last. The intermediate sprag is the first thing that will go.
Any thirdgen driveshaft from a 700R4 will work with a TH350 long tailshaft 9". If it's the short tailshaft 6" TH350 then you need a driveshaft from a 82-83 f-body that came with a 200c tranny. You also need the crossmember from the 200c tranny or modify the 700R4 mount so the the mounting perch is 2" forward. You also need the B&M conversion kit.
It's a lot easier to just buy a Spohn torque arm kit for a TH350. It will come with the proper crossmember, the torque arm mounts to the crossmember.
The only other thing you need to modify is the TH350 kickdown cable. The 700R4 TV cable bracket won't work.
92rsvortec350
19
Oct 9, 2015 09:39 AM
HoosierinWA
Oct 7, 2015 10:15 AM
