gas tank question
Old Sep 30, 2005 | 11:38 PM
Scheister's Avatar
Car: 85 IROC
gas tank question
i noticed the other day that when im down to 1/4 of a tank of gas and i go around a corner that my fuel pump gets starved for fuel. also when i am on hills or going around corners my fuel guage moves quite a bit. i was wondering if there are any gas tanks that will work for our cars that have baffles in them to stop this. if not do i just have to make sure i always have 1/2 a tank?
Old Oct 1, 2005 | 06:38 AM
Vader's Avatar
I believe the 1LE tanks have a couple weirs in them around the pump pickup.
Old Oct 1, 2005 | 08:06 AM
Charman234581's Avatar
Car: '88 Camaro RS,
Engine: 305 TBI
Axle/Gears: Stock
It is always a good idea to keep at least a 1/2 tank...because it keeps the pump cool. However the problem you are having sounds like something else might be going on...whenever mines happens to get that low I still never have a problem.
Old Oct 1, 2005 | 08:07 PM
Scheister's Avatar
Car: 85 IROC
so no one else has the this problem?
Old Oct 1, 2005 | 08:30 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
My car has a baffled tank and I even replaced the tank with one from an 1989 TA and that also had baffles.
Old Oct 1, 2005 | 08:36 PM
Hoop88Z's Avatar
Car: 1988 IROC -Z28
Engine: 5.7L TPI
Axle/Gears: 2.77
With the needle on E I have no starvation problems, not to mention that there is still 4-5 gallons of fuel in the tank on E...stupid factory gauges
Old Oct 1, 2005 | 10:19 PM
Scheister's Avatar
Car: 85 IROC
hmmm... see mine isnt like that. when i first got it i thought itd be like all my other cars that are like like that. but once i let it touch E and as soon as it touched it the car sputtered and stalled.
i have noticed when i do fill it up it goes above E. is it possible that the stock guage is just way off? i usually put more gas in it when it gets to the last white mark. when i do i usually put 5 gallons in it and it brings the guage to 3/4 full. is the guage just off?
Old Oct 1, 2005 | 10:24 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Very common for factory gauges to read weird. Typically you only have 1/3 tank when the gauge reads 1/2.
GM was to cheap/lazy to calibrate the floats to work right in our V shaped tanks.
Old Oct 2, 2005 | 08:19 PM
Hoop88Z's Avatar
Car: 1988 IROC -Z28
Engine: 5.7L TPI
Axle/Gears: 2.77
Then why is my problem that the needle is telling me that there is less fuel than there actually is? I filled today from above the 3/4 mark. 8.6 gallons. The tank is 15.9 gallons...thanks, General
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
