smog pump
Old Nov 6, 2001 | 10:37 PM
Dauntless's Avatar
smog pump
i've got this smog pump on my car. when i bought it, there was no belt running to it. i guess it's safe to assume that the lack of a pulley freed up some power. so here's my question: what is innactive due to the pump not being driven? is any of my AIR or EGR stuff working at all? if neither are working and i dont need them, then i guess i'll just remove all of that equipment. there are no emmision laws here in AL. is it really worth it to remove all of this equipment? i'll check out the documents for removal. anybody know how much room or weight this removal process will give me? thanks.
1984 Z-28, 305HO 4bbl, t-tops, K&N, Flowmaster 80 Series with 3" tips. Planning a massive modfest. It's gonna be one gangsta of a street demon.
Old Nov 6, 2001 | 10:49 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
All removing that stuff does is free up some room to work in there.
removing it saves a little wieght, but does nothing as far as gaining any HP you would ever notice.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Nov 6, 2001 | 10:56 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Dumping the smog pump is one of those 5 hp tweaks. In itself it won't really be noticeable, but if you can find four or five of those sort it will make a difference.
Old Nov 7, 2001 | 05:01 PM
Dauntless's Avatar
Ok, so how about answering my question? Does the smog pump effect the AIR or EGR equipment? If my AIR and/or EGR is not being used and I don't need them, then I'll lose all of it.
Old Nov 7, 2001 | 08:23 PM
Smeg's Avatar
Car: 1990 Black TransAm GTA hardtop
Transmission: THM700R4
Axle/Gears: 3.23 w/Alu prop
Dump the AIR, it will make it a bit easier to change the plugs
Keep the EGR, it helps detonation problems esp with low octane gas.
Im dumping my AIR system as soon as I can find bolts to fit the manifold AIR holes...
Smeg
89 GTA 5.7 TPI
Old Nov 7, 2001 | 08:30 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Yes, the smog pump is part of the AIR system, if you are removing the pump, just remove all the other stuff too.
Keep the EGR as stated above, it doesn't hurt anything and it won't give you any more hp.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
italiano67
Dec 11, 2016 09:21 AM
J.C. Denton
Aug 31, 2015 03:11 AM
Victor6
Aug 30, 2015 02:09 AM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
