Fitted distributer, whats wrong?
Old Nov 5, 2001 | 01:55 AM
Danger's Avatar
Car: 84 TA
Engine: 305 L69
Just fitted new cam, fitted distributer with timing mark on balancer at 8 degrees, the pickups under rotor lined up but the rotor should point at no 1 in the cap right? It seems to point about 10 degrees out. When I turn motor so the rotor points at no 1, the timing mark on balancer indicates its about 20 degrees advanced! What have I done wrong?
84 Trans Am HO L69 WS6
5 Speed manual
Vortech Cherrybomb no cat
JB Headers
Comp Cams XE262H-10
Removed A/C A.I.R. Hdflap
H/made tri cld air induction
K&N
Otherwise STD
Currently painting
Old Nov 5, 2001 | 07:25 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Sounds like you are close enough to fire, light it and time accordingly.
Doesn't sound like anything is wrong.
FWIW, I usually don't worry about what the pick up is doing, just #1 rotor referance on the cap.
Good luck.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
Old Nov 5, 2001 | 01:04 PM
Danger's Avatar
Car: 84 TA
Engine: 305 L69
Thanks Engineboy. I just want to be sure its going to fire up first time with the new cam and all. I thought that logically the rotor should point directly at the no1 in the cap, and I can only set it to one side or the other. How can I tell which side would be correct? I did mark the manifold and from what I can see the old timing was at 14 degrees which dosen't sound right does it?
Old Nov 5, 2001 | 09:50 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Just turn the dist to make the rotor point at #1 directly.
You would want the rotor a little to the left (closer to the drivers side) to give it a little advance, you do not want to break the cam in or run it for any length of time retarded.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Nov 6, 2001 | 02:26 PM
Danger's Avatar
Car: 84 TA
Engine: 305 L69
OK but that would require that I turn the distributer clockwise as the rotor is curently past 5 oclock and no1, so I would be retarding it. To advance it I would need to reset the distributer one tooth (which puts it before 5 oclock and no 1 in the cap) and then turn the distributer counter clockwise to line up with no1 and disregard the position of the pickups under the rotor. Does this sound right? Do I worry where the timing marks on the balancer end up or the relation of the old marks on distributer and manifold are? I don't know what the timing was set at before, but the car has given me 13 years of trouble free driving.
Old Nov 6, 2001 | 08:13 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
OK, lets start from the top.
Forget where they marks were before and forget about the relationship of the pick up coil.
TDC #1 compression with the timing marks on the balancer at 8 or 10* (it really doesn't matter where you put them, you can put them at 15 or 0* )
Drop the dist. in with the rotor pointing directly at #1 terminal.
Turn key.
I felt we were talking circles....
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Old Nov 7, 2001 | 01:30 AM
Danger's Avatar
Car: 84 TA
Engine: 305 L69
Thanks for your patience. I'll redo it tomorrow.
Old Nov 7, 2001 | 08:34 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
<font face="Verdana, Arial" size="2">Originally posted by Danger:
Thanks for your patience. I'll redo it tomorrow.</font>
Sorry if I sounded impatiant, I thought I might be misunderstanding you, so I started over..
Let us know how it goes.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
evilstuie
Jan 9, 2020 08:29 PM
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
Brcharrelson
Aug 26, 2015 07:47 PM
pimprs
Aug 24, 2015 11:20 PM
