Camshaft recommendations
Old Oct 2, 2005 | 02:43 PM
blackbetty89's Avatar
Car: 1989 Camaro
Engine: TBI 305
Ive got a 1989 Camaro, TBI 305 LO3, 100 shot of nitrous oxide, headers, untouched internals, stock heads and intake. I would like to get a more agressive cam. I want one that will give me good response on the street and when I hit "the button". Could i get some recommendations o fcams that have been used and work well with the set up I am running.
Old Oct 2, 2005 | 03:03 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Going with a roller setup?
Old Oct 3, 2005 | 11:19 AM
Car: 1989 Camaro
Engine: TBI 305
I'm honestly not sure. I was kind of hoping I could get some opinions on different set ups. I will also be purchasing new aluminum roller rockers, timing chain set, lifters, springs and valve covers. I have a good understanding of how the valvetrain system works, but I just need a little insight as to which type of products i should use to get the most out of my set up.
Old Oct 3, 2005 | 12:15 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Whats your budget?
Old Oct 3, 2005 | 12:17 PM
JesasaurusRex's Avatar
LT1 cam
Old Oct 3, 2005 | 01:06 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
I have a summit 214/224 cam, a few guys at the track said that was a good nitrous cam, dunno if it's true or not. I believe stock cam is 190/214. Anything is going to be better. A BIG cam means more stall, etc ,etc.
Old Oct 3, 2005 | 03:16 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
He wants and needs a roller cam. Don't use anything else, its a major downgrade.
LT1 cam would work good, so would a LT4 cam.
Old Oct 3, 2005 | 03:25 PM
i really think an LT4 cams a little hot for a completely stock top end
Old Oct 3, 2005 | 03:50 PM
Get a take-out ZZ4 cam.
Old Oct 4, 2005 | 03:36 PM
Car: 1989 Camaro
Engine: TBI 305
Could you guys give some reasons why these cams would be my best options? I don't really have too much of a budget, but under 250 would be best.
Old Oct 4, 2005 | 03:42 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
You can get a LT1 cam for $50.
Old Oct 4, 2005 | 03:48 PM
Car: 88 Camaro
Engine: 310 LG4
what are the specs 4 lt1 cam? is that a hot cam? what exactly is a hot cam?
Summit cams are $60
Old Oct 4, 2005 | 05:02 PM
Summit cams are $60
those are flat tappets more than likely, you want a roller
Old Oct 4, 2005 | 05:07 PM
Car: 88 Camaro
Engine: 310 LG4
what is the difference between the two? I know the differences between them, i mean physically, couldnt you use roller lifters with a flat tappet cam? I think I saw some but maybe i'm a crack smoker.
Old Oct 4, 2005 | 05:08 PM
im sure its physically possible but i wouldnt recommend it
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
