white smoke.
Old Nov 6, 2001 | 08:18 PM
gt auto's Avatar
white smoke.
Hey every time i start my car when it sits for awhile white smoke comes out the exhaust just for a few seconds. It doesent smell like oil. what else can this be?? 88 305 mpfi leeky injector??
Old Nov 6, 2001 | 08:27 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
If it doesn't have any of the tell tale smells like coolant or oil, then it may be just condensation that gets into the exhaust system while it sits. Then on startup it just blows it out, and when the exhaust actually gets hot the rest is evaporated. This is why it has to sit for awhile and let the exhaust cool, and moisture to collect in the exhaust.
Jason Lodder; 86 IROC-Z, 305 TPI/700R4, Flowmaster Exhaust, Hypertech Thermomaster Chip, K&Ns, Throttle body airfoil.
Old Nov 8, 2001 | 01:04 AM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
Are you sure it's not oil?
If it's white, its probably oil. Mine does it, too. Most old engines seem to... everyone I've ever asked acts like that's just life and you have to deal with a little oil seepage unless you want to rebuild it...
Anyone know any simple potential fixes for this? Or do you really have to get jiggy with a rebuild to fix it?
Old Nov 8, 2001 | 01:23 AM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Sounds like the classic 'oil leaking past the valve seals' to me..... The guides also tend to get worn out over time and sometimes actually cause the seals to go.... either way, better quality valve seals should take care of it.
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 8, 2001 | 07:06 AM
gt auto's Avatar
Hey if I yank the heads and have a valve job done will this do anything to the bottom end?? It has 125000 miles but runs strong. or just take and do a rebuild on the motor
Old Nov 8, 2001 | 11:08 AM
86BIRD-MY FIRST CAR's Avatar
what about that STP smoke gone stuff?
86 firebird 2.8
K&N replacement filter
modified air box
MSD ignitor
Hooker cat back
GNX style wheels
Old Nov 8, 2001 | 05:26 PM
lunas's Avatar
my 87 trans am does the exactsame and its at 135000. its oil, its normal on old engines. dont worry too much about it. My freinds 89 camaro does it too
Old Nov 8, 2001 | 05:40 PM
SoCo80p's Avatar
oil will huff bright blue, coolant will be white, sounds to me like its just condensation in the pipes, most all cars are like that
Old Nov 8, 2001 | 06:34 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Barring Coolant or condensation in the exhaust if you have a TH350 it could be auto
trany fluid being sucked up throu the vacuum modulator line into the intake. A blown modulator diaghram will do this.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
89bird2.8
Sep 25, 2015 09:21 AM
KCG
Sep 23, 2015 09:05 AM
