Temp sensor wiring?
Old Oct 3, 2005 | 12:24 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
Temp sensor wiring?
I bought a new temp sensor, it has 2 wires a black one and a yellow one. Which wire is for what? Does the sensor get ground from the block or what? No I dont have an original temp sensor, nor do I have original wiring, so I cant tell from that. Any ideas? I tried different variations with my temp gauge, but nothign really seemed to work.
Old Oct 3, 2005 | 12:30 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
same idea here, i gave my old heads away and it had the temp sensor on them, i will need to rig one up, id like to know how to do this, but i also have a temp gauge in the car, so i need to know how to get it installed to that.
Old Oct 3, 2005 | 12:31 PM
That is a coolant temp sensor for the ECM. It has nothing whatsoever to do with the gauge, except that they both happen to be immersed in coolant.
I can't begin to guess whether that would work a gauge. Somehow I rather doubt it though.
You are correct about its wiring, the black wire goes to ground, and the yellow wire goes to the ECM.
A temp gauge sending would have one terminal, and a dark green wire will go to it.
Old Oct 3, 2005 | 12:45 PM
Car: 88 Camaro
Engine: 310 LG4
DOH! I never thought about that. Crappity Craptastic. I will have to get a new one then.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
