Starter of VATS ?
Old Nov 7, 2001 | 07:03 PM
phineas's Avatar
Starter of VATS ?
My car has recently developed a starting problem. When I go to crank it over, I hear the standard solenoid 'click', but the starter doesn't engage. After a few tries, it'll turn over and start right up. Normally that tells me the starter is on it's way out, but I'm new to this VATS stuff so I just want to rule that out. I'd imagine VATS wouldn't even get the power to the solenoid, but I'm sure some of you out there know a heck of a lot more about it. Thanks!
Kyle
Old Nov 7, 2001 | 09:52 PM
Ovrclck350's Avatar
OK, I COULD be wrong, but I don't think so in this case (I always say that to cover my @$$). It's not Vats...my guess is it would be your actual starter. If you hear the solenoid click, then you're getting power down there, if it was VATS then you wouldn't recieve power to the solenoid, and your SECURITY light would stay lit. Also, you wouldn't be able to start your car for 10 minutes or so. But since you say just a couple of tries and it starts, then it's not VATS.
Old Nov 8, 2001 | 01:29 AM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
You have to wait 5 min. to start
with the vats
Old Nov 8, 2001 | 03:33 PM
snakeskinner's Avatar
vats totally eliminates power to the solenoid or injectors. look at the electrical ignition switch (not the key & tumbler), wiring, solenoid, relay or starter. check for voltage drops through the system.
Kyle Osterholt
Okarche, Oklahoma
ASE Master Certified
86 T/A 383 TPI
89 TTA #1002 T-top/Leather
89 TTA #1358 Hardtop/Leather
80 T/A Pace Car
73 Opel GT
73 bronco
2000 Ducati 996 Monoposto
Old Nov 8, 2001 | 08:22 PM
CC's Avatar
CC
Car: 1989 Trans AM GTA
Engine: 5.7 TPI - Stock
That clicking sound indicates the starter needs to be replaced.
'89 GTA 5.7 TPI bone-stock
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
