what is wrong??????
Old Nov 4, 2001 | 07:05 PM
okieKILLA87's Avatar
what is wrong??????
ok here is my situation i kinda ran out of gas last night as i was pulling into the gas station and i put some gas in and after i put the gas in my car was acting like it was still out of gas. every time i stopped at a light it would sputter and die. and this morning when i drove it it was fine for about 15 miles and it started acting up again. then tonight when i drove it it was fine for about 10 miles and it did it again.
Old Nov 4, 2001 | 07:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If this is a FI car, or a carb car with an in-tank fuel pump, then the pump is incapable of surviving with no fuel. The fuel is its coolant. Without being submerged in fuel, the pump motor burns up.
At the TV station I worked at for some years, we had several F*rd vans. The newer ones had a problem with their gas gauge such that it would break about every 6 months or so. Then the photogs would jump in and drive them somewhere, and they'd run out of gas. About twice of that was all it took to toast a fuel pump. One of them (a 98 model) was on its 3rd fuel pump and gas gauge sending unit when I left the station in mid-2000, all of them under warranty.
ICON Motorsports
Old Nov 4, 2001 | 07:51 PM
rezinn's Avatar
Change your fuel filter. When you run out of gas one of two(or both) things happens in my experience:
1. The fuel filter and/or lines become clogged with crap at the bottom of the tank. 2. The fuel pump dies.
Old Nov 5, 2001 | 01:08 AM
my dad tested the fuel pressure and it is perfect so i dont think it is the fuel pump or filter. does anybody else have any other suggestions? it is a 1987 305 TPI trans am. also the fuel pump is brand new
Old Nov 5, 2001 | 12:47 PM
88firebird305's Avatar
put some dry gas in tank, or maybe fuel injector cleaner? see if that helps.
Old Nov 5, 2001 | 10:55 PM
what exactly is dry gas? ill try the fuel injection cleaner tomorrow. thanks
Old Nov 6, 2001 | 11:24 PM
GOLD85's Avatar
to you have fuel presure when your car is acting up.
when the green flag drops the bull$hit stops
Gold 85 Camaro with no motor, pulled the 2.8 to make way for a 350 wich was pulled this summer because a 406 will replace it. The 406 sports a stock bottom end with ARP bolt holding it togeter, flat top hyper pistons. Comp 282 solid cam(.528 lift with 1.6 rockers) Savin up for my Sportsmen 2 heads right now. still Have the perf RPM and 650 DP i used on the 350. Headers and 3inch exhust. Shooten for mid to low 12s next summer
Old Nov 7, 2001 | 08:13 AM
WideOpenVTwin's Avatar
Car: 1992 Camaro RS
Engine: 355
Axle/Gears: 3.73:1
<font face="Verdana, Arial" size="2">Originally posted by okieKILLA87:
what exactly is dry gas? ill try the fuel injection cleaner tomorrow. thanks</font>
Dry gas is alcohol. It bonds with water and will still burn, therby removing water from your tank. They sell it at most parts stores, and all marine stores.
Old Nov 8, 2001 | 11:31 PM
i have perfect pressure when it is acting up thats why i am dumbfounded as to what the problem is. and i havent had time to look into it lately because of school. this really sucks. its starting to do it more frequently now too
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Dyno Don
Jan 24, 2016 08:24 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
