ENGINE DIFFERENCES BUT SAME ????
Old Nov 8, 2001 | 10:15 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
I ve noted that certain engines are the same
Example: a 74 350 2bbl code LG5 is rated at 145HP@3800 AND 250lbs@2200
and a 74 350 2bbl is rated at 160HP@3800rpm and 250lbs@2400 both with 8:5:1
what makes the differences
i cant figure it out ???
Old Nov 8, 2001 | 11:12 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Are you sure they have the same engine code, maybe different codes got different cams.
"Putting any amount of money into a RICE BURNER is like wiping your a$$ with a turd. "
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Nov 8, 2001 | 11:21 PM
Calderone's Avatar
Car: 87 Vette
no ...they have different codes
EXAMPLE :
LM1 4BBL 160HP@3800 250LBS@2400
L48 4BBL 185HP@4000 270LBS@2600
BUT WHAT DIFFER ? THEY ARE 350s AND 4BBL
BOTH ...CAMS CHANGE ?
Old Nov 9, 2001 | 07:29 AM
Car: 99 Formula
Axle/Gears: 342
I know thirdgen's of different years that have different HP the main reason because the LG4's got peanut cams and others got better one's. But it could be other things for those 350's.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Old Nov 9, 2001 | 07:38 AM
ede's Avatar
ede
cam, heads, exhaust, intake, timing, jetting, any number of things can change preformance and HP figures
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
masonta
Aug 31, 2015 10:14 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
