Motor mount installation?
Old Oct 8, 2005 | 05:08 PM
SandPump's Avatar
Car: 87 IROC Z28 Camaro
Engine: 350 SB
Do I have to jack up the engine to install motor mounts?
Hello,
My Chilton doesn't really explain what's needed to change my motor mounts. Can anybody give me some tips on what's involved? I would like to do it myself but if it's too much hassel I will just give it to my mechanic. Also, I am thinking about upgrading to the urathane mounts. Anybody try these?
PS: 87 IROC 350. (California car)
Old Oct 9, 2005 | 12:42 AM
SandPump's Avatar
Engine: 350 SB
Hey guys, if this is in the wrong section let me know. But if anybody knows, please reply!
Old Oct 9, 2005 | 10:29 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
I saw a post not to long ago that read (change your motor mounts hear or best way ) do a search with any combo . When I didem a few years back it took all day , but not hard to do . I remember I had to tape the nut to the wrench to hold it in place . You will see what I mean .
Old Oct 10, 2005 | 03:29 AM
SandPump's Avatar
Engine: 350 SB
Thanks bud. I think I found just what I feared. Sounds like it will be a big PITA. Here goes nothing lol.
Thanks again.
-Jason
Old Oct 10, 2005 | 04:07 AM
CrimsonDragon's Avatar
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
If you go with the Urethane motor mounts prepare for a whole lotta shakin and engine noise as they transmit a great deal. I have gone with the rubber motor mounts and urethane trans mount and it is pretty streetable.
Old Oct 11, 2005 | 04:34 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
bolt replacement
When you put the new mounts back in, it's impossible to get the nuts on from the underside of the upper bolts - but it's not that hard to put the bolts in from the bottom, if you have swivel adapters and extensions. And, it really makes no difference which way they go. Some will argue that if the nut comes loose, the bolt will fall out and leave you with no mount, but I'm sure you'll feel the massive vibrations from a bolt being loose LONG BEFORE anything actually falls out. I had a bad mount, and you'll know long before it "falls out".
Old Oct 11, 2005 | 05:00 PM
TA_drag's Avatar
Car: 85 Trans Am
Transmission: t5
good idea
thats a good idea , turning the bolts upside down. I did mine recently and while not impossible to get the nuts on it was a pain. I had to get creative with u joints and extensions etc. I went to moroso solid mounts.
Old Oct 15, 2005 | 05:13 AM
Tony89's Avatar
Car: 1989 IROC-Z Convertible
Transmission: Art Carr 700-R4
possible compromise
There is some information out there (TGO?) about a "compromise" between polyurethane engine mounts and the rubber ones. Import guys have been doing this for some time, and I think there are people on these boards who do the same.
Get ahold of some 3M "Windo Weld." It appears just like silicone caulk in a cartridge, but it's urethane material, in thick liquid form. Use a caulking gun to fill the gaps in a regular old stock replacement rubber biscuit engine mount and get the best of both worlds: enough pliablilty to absorb engine vibrations, but enough stiffness to help "tighten" up the feel of the mounts. Think of the mount as a progressive rate coil spring: it's fairly pliable (streetable) under normal use, but when pushed, it has firmer material surrounding the rubber insert, bolstering it. I saw a write up by a guy with an MR2 and it seems to have been a worthwhile project. It's just my two cents but not everyone knows about this one. Good luck.
Old Oct 15, 2005 | 12:11 PM
88_Import_Slaye's Avatar
Car: 88 Camaro
Engine: 310 LG4
Transmission: 700R4 w/2200 stall
same.
It was a biotch to change my mounts for the swap, spent a good 2 hours fishing for nuts and bolts and rigging up custom tools to get in and at the end of the day all I had to say was "Good enough!"
it might be easier for you, you can drop the a-arm and do it that way, i didnt so it was super hard.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
