Odd ticking inside the car
Old Nov 9, 2001 | 11:57 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I don't think its an exhaust leak. I have listened to the engine bay and all i can hear are the injectors. The noise seems to be coming from the center of the car in the dash somewhere. Could it be possible that the climate controls have a slight leak? The controls work fine except i think that the AC compressor comes on when i turn the defrost on... unless thats normal. Anyone have some ideas?
Old Nov 9, 2001 | 12:14 PM
rezinn's Avatar
I would also like to pose this question. My father purchased an 88 supercharged mr2 with 60k on it from my uncle, and I noticed that when the a/c is on I can sometimes hear a ticking noise. Just a few ticks at a time, not all the time. I noticed it more when we were braking(I may have been imagining this).
Old Nov 9, 2001 | 01:17 PM
Omega's Avatar
Engine: LS1 / LS3
When my AC is on, you can here a grinding noise. I assume that the bearings are shot in the compressor. You might have a similar situation with just a few of the races having a flat section. The increased noise while braking is interesting though.
Old Nov 9, 2001 | 03:04 PM
LastHopeRS's Avatar
the ticking might be your compressor, possibly maybe even an arcing spark...or...this, which is a real long shot (depending on how loud this ticking is) your coil!?! have you replaced it at all with an aftermarket?, because i know i can hear my accel coil ticking through the firewall, because thats where it is screwed in. i usually just turn the music up. just a thought...good luck.
Old Nov 9, 2001 | 04:39 PM
Omega's Avatar
Engine: LS1 / LS3
I don't think its an arcing spark plug/wire. I don't have an aftermarket ingnition. I can't hear it in the engine bay, only in the car.
Old Nov 9, 2001 | 06:33 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
I had a ticking that sounded like it was coming from the dash board. I thought that my speakers had **** the bed so I replaced them. As it turned out it was the tripmeter in the speedo got jammed and kept trying to tick over but couldn't...
Its a long shot, but you never know...
Mike
1989 RS.. 355, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch, 3 angle valve job, 3 inch cat-back exhaust, 3 core radiator, 3.73 gearing with POSI.
Old Nov 10, 2001 | 02:53 PM
Omega's Avatar
Engine: LS1 / LS3
Nope, not the trip.. that works fine. Its engine related. It does it when the car is in park. Its just SO annoying!!!!
Old Nov 10, 2001 | 03:44 PM
nativ's Avatar
my trip meter does the same thing. since some odometers are elec. it could be trying to flip over even when siting still.
Old Nov 10, 2001 | 09:16 PM
burntblues's Avatar
Car: 1989 Camaro RS
does it only happen when your heat, ac, or vent is on? if so, it could be some debris caught in the vents or in the blower... but if its when its only in park, I don't know...
could be lifter noise maybe?
-=-Mike
Old Nov 11, 2001 | 11:35 PM
Omega's Avatar
Engine: LS1 / LS3
It happens when the blower is on and off. I don't think its the lifters. There is no unusual noise in the engine bay.
Ghettobird52
Jul 5, 2024 11:18 PM
mustangman65_79
Aug 11, 2015 03:17 PM
draco
Mid-West Region
Aug 10, 2015 09:18 PM
mustangman65_79
Aug 7, 2015 09:55 PM
z28addict8490
Aug 7, 2015 08:48 PM
