code 34....maf or ecm???
Old Nov 13, 2001 | 01:33 PM
85transamtpi's Avatar
My car just flashed a SES light at me last night. The car was running poorly, and had an irratic idle. The car died on me, and when I started it again the SES light went off and it drove normaly. I pulled the code at lunch today and checked the connection on the MAF. Is there any way to tell if the MAF is broken without replacing it? I know they are pricey, and it would suck to replace it and find that the ecm was the problem. Any advice?
thanks
Old Nov 13, 2001 | 01:54 PM
mtccl's Avatar
My code 34 was a loose fitting upstream of the MAF. Tightened the hose, zeroed the ECM and no code. Also there is a MAF on e-bay now cheap. Check the wiring also.
87 TA, 305 TPI, Custom CAI, K&N, ACCEL 8mm wires,ACCEL Super-coil, ACCEL Plugs, JET TPI Airfoil, Cherry Bomb Muffler
The Phoenix Project..click to see my project car
Trans Am stuff and GIRLS, GIRLS, GIRLS!!!!!
Old Nov 13, 2001 | 03:09 PM
Okay,
I did a search and plan on checking relays, ducting, MAF sensor connections, and TPS voltage after I get out of the office. The only reason I asked about ecm is because there is something listed about a code 34 and a bad ecm in my repair manual. I'll post further if everything checks out and I get the code again.
thanks
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
eustodp
Sep 20, 2015 05:09 PM
Reese-J
Sep 14, 2015 02:43 PM
RyanJB
Sep 2, 2015 01:27 PM
