How far does the knock sensor need to be screwed into the block??
Old Nov 13, 2001 | 11:02 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I just put my new engine in my TA and I went to put the new knock sensor in and I can't get it to screw into the block all the way. I'd say it might be half way in. It's tight and I don't have the proper size wrench as it is anyhow. It's not a 3/4 and not a 7/8 so I'm guessing it's metric... unless it's a 13/16. Do you think this will be ok?? Will the knock sensor work properly this way or should I find a way to screw it into the block farther? Thanks in advance.
1986 Trans AM
305 TPI
Well over 200,000+ miles (speedo/odometer non-funtional! Odometer reads 142,000)
4 Wheel Discs
9 bolt Borg Warner Rear (2.77's....oh joy) :P
Completely Stock
Current Project: upgrade to a 355 TPI, 6" rods, 9.7:1 Compression, Stock TPI ported, 24#/hr LTI injectors (cleaned and flowmatched by Cruizin Performance), Hedman Shorty Headers, 3" exhaust with 80 series flowmaster, SBC 993 heads completely redone and modified for 1.6 RR, Comp Cams XE262-14 TPI Cam, Holley AFPR, TPIS airfoil, MSD wires, MSD 6-AL Ignition, Hypertech hot coil.
Old Nov 13, 2001 | 11:53 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It only needs to go in until it stops leaking. The threads are tapered pipe thread, since after all it replaces the pipe plug that drains the water jacket; it's not a straight thread like a bolt or something, so don't expect it to necessarily go all the way in. I'd guess something around 15-20 ft-lbs is entirely enough. Use about 4 wraps of Teflon tape, and whatever you do, don't overtighten it. That will make it overly sensitive.
IIRC 13/16" is the correct size. I usually use a 6-point socket to make sure I don't strip its hex.
ICON Motorsports
Old Nov 13, 2001 | 12:18 PM
TPI Guy's Avatar
Car: 1968 Camaro
Engine: 406
Transmission: Tremec TKO
Won't the teflon sealant effect the sensor's ability to detect knock frequency? I don't think they used sealant from the factory
Old Nov 13, 2001 | 01:08 PM
<font face="Verdana, Arial" size="2">Originally posted by TPI Guy:
Won't the teflon sealant effect the sensor's ability to detect knock frequency? I don't think they used sealant from the factory</font>
That's what I read somewhere too. The threads have something on them already. I guess it wouldn't be bad to de-sensitize the knock sensor a little ... since I am going with headers which have a tendency to cause false detonation due to resonation. Anyone else have any opinions on this part?
Old Nov 13, 2001 | 02:19 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
I used a liquid teflon on the threads so it wouldn't leak (I was reinstalling the old sensor on my rebuild). I don't really know if this was a good idea or not, or if it will affect the sensativity of the sensor. Opinions?
91 Z28
Come see The Vicious...
Old Nov 13, 2001 | 02:41 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I used liquid teflon on mine and it seems to be a little less-sensitive than it should be, but I am not complaining....
1987 GTA L98 MD8
355, TFS Heads, LT4 Hot Cam
My GTA
The Minnesota F-body Club
Old Nov 13, 2001 | 03:38 PM
RICH92RS350's Avatar
Car: 92 Camaro RS
Engine: 350 Crate Motor
Axle/Gears: 10 Bolt 3.73
I recently bought a brand new knock sensor from GM (AC Delco) and it comes with a thread sealant already on it (kind of orange in color),so I gotta figure, if GM puts sealant on it , it should be ok for it to have sealant on it.
Any of the teflon-based thread sealants should be fine as well.
-Rich-
9192camaro
16
Feb 3, 2019 12:21 AM
Chuck84TA
Jul 15, 2016 09:05 PM
db057
Sep 4, 2015 07:57 AM
bamaboy0323
Sep 3, 2015 06:07 AM
