Help!! Cant identify this noise
Old Oct 12, 2005 | 10:40 AM
Matthew91-Z28's Avatar
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
I heard this noise the other day on the highway....its like a whine/ with mild grind almost like something is rubbing against a rotating part.
It gets noticably louder when I take my foot off the gas. And applying the brakes doesnt change/affect the noise at all.
And it also gets louder when I take a right turn.
Its sounds like its coming from the right rear but I cant be sure.
And it only makes this noise when I'm drving. I can park it and pop the hood and hit the throttle and I hear nothing strange at all.
I thought it was my axle bearings. I've had a leaky axle seal for a while. I replaced bearings and seals yesterday and noticed also that there was only about 1 pint of gear oil in my case and I blew a side gear shim in my diff. So I replaced the shim also and put it all back together just fine.
Everything I did to the rear yesterday did not effect this noise at all. Same quality and same frequency.
This doesnt feel like a brake issue (no other brake problems). I need to put it on blocks and put the car in drive I think to see if anything is rubbing the driveshaft.....I dont know. I'm at a loss.
Anyone have suggestions?
Old Oct 12, 2005 | 12:34 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
worn crown and pinion maybe? or just not aligned properly.
Does it make the same noise under light acceleration?
Old Oct 12, 2005 | 01:09 PM
Not really.....its the same quality of noise but very faint with acceleration.
Old Oct 12, 2005 | 06:23 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Sounds like wear on the Decel side of the ring and pinion. An axle bearing would make the noise all the time.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
Linson
Sep 21, 2015 01:08 PM
Randomtask2
Sep 7, 2015 05:06 PM
