Poor starting?HELP!
Old Oct 12, 2005 | 01:34 PM
M@88iroc's Avatar
Car: 1988 Camaro IROC Z28
Engine: 5 Litre V8
Poor starting?HELP!
My V8 5ltr 88 iroc does start but takes alot of cranking. I can here the fuel pump priming but does sound a bit rough? Is that the problem or is it pressure reg failed alowing fuel o frain back to the tank? Any help or advice is good!
Cheers
Old Oct 12, 2005 | 02:52 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
Re: Poor starting?HELP!
Cheers
if the regulator doesnt work the car would run like crap. get a guage on that shrader valve and see what your PSI is.
How long has it been since you changed your spark plugs?
Old Oct 12, 2005 | 02:54 PM
M@88iroc's Avatar
Engine: 5 Litre V8
poor starting
ive had th car a year, ive done 20,000 miles so yehprobly bout time i changed the plugs? what psi shud i have ?
Old Oct 12, 2005 | 05:26 PM
sellmanb's Avatar
Car: '86 Berlinetta
I see you're in england, that is cool
Things to check - fuel pressure.
Check it before you even put the key in it in the morning.
Then turn the key to the "on" position and check the fuel pressure.
Then have your wife/kid/neighbor/someone walking the street crank the car while you watch the cranking fuel pressure
Check idle fuel pressure
Check WOT fuel pressure
Check it after you turn the car off
Check it 5 minutes after you turn the car off
Check it 10 minutes after you turn the car off
Check it 1 hour after you turn the car off
(those 4 w/o putting the key in the igntion)
report back with numbers
Check your timing. Stock it should be 6* advanced (with the EST unplugged).
If all of that checks out OK you can always bring your starter in to just about any parts store (atleast here in the US you can) and ask them to test the starter.
Good luck and report back
Old Dec 19, 2006 | 10:08 AM
M@88iroc's Avatar
Engine: 5 Litre V8
here i am a year later an the head gasket has finally given up! wata bitch of a job that was. recon it was that in the end ani was jus ignorin it.
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86IROC112
Aug 21, 2015 07:20 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
