Cylinder Head Sensor?
Car: 1992 Camaro RS
Axle/Gears: Stock
Okay quick questions. There's a sensor that screws into the side of the passenger cylinder head (roughly between cylinders 6 & 8) and I believe it goes into the water jacket. My questions are: What is it? Do I need it? Because the little prong that plugs into it is deteriorated and won't stay in there. So is it necessary, or is it another one of those sensors I can forget about? Thanks.
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
THat is your fan temp sensor.
Car: 1992 Camaro RS
Axle/Gears: Stock
Sounds important. Do I need it?
*Edit*
Stupid question, yes I do. Damn. The rubber sleeve that wraps around the metal prong fell apart. And it seems as though that rubber sleeve held the prong in place. So how the hell do I fix this....
*Edit*
Or a parts store.
You can get about a 6" pigtail with that connector on it at AZ IIRC. Just splice that onto the end of your wire.
they had no idea what I was talking about
Did you walk over to the shelf and look? It'd probably be laying right there staring up at you, like the one was in da store in my hood last weekend.
Car: 1992 Camaro RS
Axle/Gears: Stock
I really wasn't expecting them to be any help. But they tried.
Anyway, I just bought a little piece of hose to replace the rubber sleeve that wrapped around the connector. Thanks for the help.
Car: 1992 Camaro RS
Axle/Gears: Stock
Okay, does that sensor work the temperature gauge? Because I got the car running again, and the temperature gauge doesn't want to work...
on my car the temp gause sensor is on the drivers head.
here is what my temp gauge sensor looks like...is this the gauge your talking about?
Car: 1992 Camaro RS
Axle/Gears: Stock
Yep that's the one. I just remembered that I never found the connector for it. It's in the engine bay somewhere, I'm just not sure where...
Thanks a lot.
Thanks a lot.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Temp guage:driver's head, fan switch: pass head. Sensors appear identical but they are not. Your fan switch will have a single wire running to the fan relay near the windshield wiper motor (unless the location changed for different years) it will provide a ground at a specified temperature to engage the relay and provide power to the radiator fan motor. Look for this wire coming out of the harness near the rear of the engine.
The temp guage sender will provide variable resistance to ground to the temp guage needle, if you have a guage. If you've got the really cool idiot lights this sensor will provide a ground to turn on the temp lamp, again at a specified temperature, although a higher temp than the one to engage the fan.
Car: 1992 Camaro RS
Axle/Gears: Stock
Okay, does anyone have a picture of the connector for the temperature sensor (in the driver's head) or know where the hell it is? Because I can't seem to find it...
I doubt a pic would do much good, for identifying something you can't see....
"I see" said the blind man to his deaf wife over the long-distance telephone line that wasn't connected, as he picked up his hammer and saw....
The wire you're looking for will come out of the same general area as the wiring breakout that has the dist wires and the OPSU wire. It will be dark green; a single wire, all by itself. It should run along the driver's side edge of the intake, and cross over the valve cover about at the PCV hole.
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Look a little further down just above the oil pan rail and you'll see another one identical to it - It's the Knock sensor, but your's is a "92 so connector may not be the same as on my '88.
Car: 1992 Camaro RS
Axle/Gears: Stock
Never mind. I found it. Apparently the square connector I kept looking at attaches to the round sensor.
Go figure...
Thanks a lot guys. It's working again. Now I just need to figure out why it's running lean...
Go figure...
ambainb
Apr 25, 2016 09:21 PM
NinjaNife
Aug 23, 2015 11:49 AM
