How To Re-tap A Thread??
Old Oct 12, 2005 | 02:52 PM
roughskinjrz's Avatar
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
can you buy kits for this
my intake was leaking, so i took it off filled the china wall with gasket maker, and put a bolt back in and it wouldnt thread, i took it out and there was piece of metal in the bolt.
so im guess its ****ed, is my best bet to re-tap it?
Old Oct 12, 2005 | 03:06 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Use a helicoil kit. Drill out the damaged threads to the size printed on the package, tap it with the included tap, thread in the helicoil with the included tool.
Old Oct 12, 2005 | 04:03 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
You may be able to just clean up the threads with a chaser and get the bolt to seat. If the threads in the head are damaged then you will need to helicoil it as mentioned above. EDIT: Make sure you didn't just gum it up with the sealant.
Pac J
May 17, 2020 10:44 AM
Elephantismo
Feb 13, 2019 12:51 AM
Fred SS
Oct 12, 2015 11:27 AM
Linson
Sep 21, 2015 01:08 PM
