What can I expect L98 heads/cam to do for an LO3?
Old Nov 14, 2001 | 08:17 AM
Mike-88CamaroTBI's Avatar
Subject pretty much sums it up.
I already have an L98 cam in great shape and I am buying L98 heads ASAP. I currently have an open element air filter and a well tuned engine. A new 3" catback should arrive this week. I have an L69 Y pipe and i am getting the L98 exhaust manifolds also. I will port match the head's and my stock intake to the intake manifold gaskets. I am going to deburr/polish the exhaust ports also.
I know this is a somewhat curious hodgepodge of parts. I just want my car to be in the 225HP to 250HP range with over 300 ft lbs of torque.
Will I gain low end torque or lose low end torque.
I am pretty sure it will have more HP but I have no idea how much more.
Should I mill the heads and if so, how much??
If you are positive from your experience that this combo will not get 250HP/300TQ, what could be done for a low cost to get it there?
1988 Camaro Sport Coupe305TBI-4spdAOD-2.73open in "bought stock" condition. That'll change if it stays around here much longer mike.davis@firstunion.com
Old Nov 14, 2001 | 08:32 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
The L98 heads that you speak of, are they the Corvette aluminum? If so, it would be a good move. They flow better than the 305 heads and they have a 58cc combustion chamber so you won't loose compression.
If it's the cast iron heads from a Camaro or
Firebird, you will loose power due to the larger combustion chamber.
www.geocities.com/dzperf
D&Z Performance
"Putting Power to the Pavement"
Old Nov 14, 2001 | 08:55 AM
85transamtpi's Avatar
If you are using L98 iron heads your compression will drop a lot unless you mill them down a lot. The aluminum L98 heads are very good out of the box, but they may need modification (EGR, bolt holes). If I were you I'd ditch the exhaust manifold idea and just run some headers. Desktop dyno results show me that this can be one of the best mods on a stock engine, and logs will seriously restrict a built engine. The L98 cam should work nicely. I'm not sure what kind of power you'd be running. You may want to ask the tbi board, they will be able to estimate better than I can.
good luck
Old Nov 14, 2001 | 10:54 AM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I'm assuming that your buying the 'vette L98 heads...
You're gonna have to enlongate the bolt holes on your stock intake to get it to bolt up to the 'vette heads. The other thing that you might have to watch out for is computer tuning...the stock chip might be able to handle it, but I'm not sure. Just be prepared if it doesn't.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Nov 14, 2001 | 12:24 PM
The heads i am getting are the cast iron L98's. I can't begin to afford the aluminum ones right now. So the iron L98's are either 60cc or 64cc depending on where i look. Any idea how much milling?? Well,
one good thing is that after a mill i will have a perfect surface for the new head gasket, at least on the head side.
Old Nov 14, 2001 | 01:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Cast iron are 64cc.
You'll need to remove about .007"/cc, so to drop 6 cc, you'll need to remove .042".
Get the intake machined to match so you don't have oil leaks when you get it back together.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2200 stall TC. Ported World 305 heads, Crane PowerMax cam. ZZ4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster. 2.93 limited slip, Spohn SFCs. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
91chevyz28
Feb 10, 2022 07:58 PM
FormulasOnly
Jul 23, 2018 08:47 AM
hartsmike
Oct 2, 2015 07:11 AM
anesthes
Sep 21, 2015 10:24 AM
scottmoyer
Sep 7, 2015 07:06 PM
